DHRA work stock rules
Old Oct 24, 2006 | 02:33 PM
Teddy Bear's Avatar
Since the Dmaxes have started pulling, a lot of the local pulls around have changed the rules of the "stock turbo" class to a "2.4 inducer class". This allows the cummins to be on a more level playing field with the Dmax since the stock turbos on the Dmaxes can flow much more air than the HX35s can. The DHRA work stock class is still limited to a stock turbo. How likely is it that the DHRA will change the rules of the workstock class?
Old Oct 24, 2006 | 03:46 PM
halerazor's Avatar
i doubt they will change it i've been crying about this since the beginning of this year. they are worried about someone dropping money into a 12v and winning the class and they want to make it a class that anyone can run without sinking lots of money into their trucks. so just get rid of that 12v and go buy a new $50,000 truck if you want to compete in work stock
btw the rules allow a 2.5inducer turbo here in ohio and it keeps the class pretty close.
Old Oct 24, 2006 | 04:12 PM
House's Avatar
lly and lbz chargers are 2.59
Old Oct 24, 2006 | 04:46 PM
halerazor's Avatar
they still allow the dmaxes to pull even though they are a little bigger. a sps62 will put you right there with them
Old Oct 24, 2006 | 08:12 PM
Teddy Bear's Avatar
Thats what ive got. Im not planning on pulling everywhere with the DHRA, probably only 3 hooks with them at the most per year. But if i wanted to hook with DHRA, that puts me in a class where im waaaay outta my league Dmaxes are plenty capable of making 500HP on a stock turbo. Not because its just that much better of a motor, but because they simply have enough air to do so. It only makes sense to me to let others run a turbo thats around the same size as the Dmaxes.
Old Oct 25, 2006 | 01:57 AM
joefarmer's Avatar
Please forward your comments to tech@dhraonline.com - That way your voice is heard and considered.
brandon.
Old Oct 25, 2006 | 09:29 AM
signature600's Avatar
It doesn't hurt that they have 2 heads the EACH flow better than ours either
Chris
Old Oct 25, 2006 | 01:46 PM
Teddy Bear's Avatar
Chris
Exactly. The Dmax boys still cry about the 2.4 rule we have around here. I think theyre just skeered
Old Oct 25, 2006 | 01:48 PM
Teddy Bear's Avatar
brandon.
Thanks man. I'll send them an email sometime soon. Im definitely not the only one around here that wishes they would switch to the 2.4 rule.
Old Oct 25, 2006 | 04:21 PM
strokethis600's Avatar
No make it a 2.5 so the SPS66 boys can run in it.
Old Oct 25, 2006 | 07:25 PM
wana12v's Avatar
last time I checked a 66mm is an 2.6
Old Oct 25, 2006 | 08:34 PM
halerazor's Avatar
62=2.44in
64=2.52in
66=2.6in
Old Oct 25, 2006 | 09:47 PM
ya sorry brain fart
Old Oct 25, 2006 | 10:14 PM
Teddy Bear's Avatar
62=2.44in
64=2.52in
66=2.6in
Yeah i was thinkin that the 66 chargers were pretty big, bigger than the dmax chargers any way. I actually had Shane at Industrial Injection customize the housing on mine so the inducer size would be exactly 2.4
Old Oct 25, 2006 | 10:57 PM
cumminsdriver635's Avatar
I think they are scared, because the good running CR trucks with only a hx35 can pull with em already. Give em a little air to breathe and the d-max's are done for. Of course an old 12v with a little air aint to shabby either
Eric
