Clutch Clearence Problems
Old Oct 31, 2009 | 03:44 AM
98 12v's Avatar
This is the same as i posted in the performance 2nd gen. Just trying to reach more of a group of minds.
I just got done rebuilding the motor in my 98 and purchased a new DD clutch from kennys for my truck. After installing on the motor and shoehorning the motor back in, i was unable to turn the engine over. The head was off so i know its not somthing like a valve hitting and the motor spun freely before insalling. I loosened the bellhousing bolts and was able to spin the motor over again but could hear the clutch housing/pressure plate rubbing. I figured it was something i had done wrong so i pulled the motor back out to check. The clutch was rubbing so hard on the bellhousing it left scratches. Has anyone else ever had issues like this that could lend some insight? I was told the clutch has a 3800lb spring pressure. It uses a bunch of small fingers instead of the 4 big fingers the picture shows on his site and also looks bigger around the outside edges. Is there a different bellhousing i need or is it safe to grind on the clutch or bellhousing to gain clearence? Any help will be greatly appreciated
Old Oct 31, 2009 | 07:03 PM
renopker's Avatar
If you see were its hitting get the 4" grinder after it,I have spent many hours in side a bell housing making room. good luck
Old Nov 1, 2009 | 12:28 PM
98 12v's Avatar
Theres enough extra aluminum thickness to do that? The bellhousing seems pretty chinsy already to me and im afraid if i take to grinding on it it will get weaker and break. Nobody makes any kind of an aftermarket bellhousing or what?
Old Nov 1, 2009 | 08:19 PM
renopker's Avatar
If its that much call kenny the hight of the fingers might be to high,floaters to thick,disc to thick ??
whereswaldo250
Jul 24, 2006 05:48 PM
Kuntry
Sep 29, 2005 08:26 PM
sdscuba
Jan 11, 2005 05:01 PM
racermatt2606
Oct 5, 2004 02:14 PM
BADodge2003
Mar 8, 2004 08:40 AM
