Can I pull it (drw v-10)
are you guys kidding me, i pulled a v10 ext cab with my 96 2500 and it only had a #6 plate. we pulled in the dirt and both of us just spun, then we took it to the street and i didn't even know he was behind me except for the glare of his brake lights in my rear view. it wont even be close
Originally posted by blackdiesel02
ive got a buddy with the same set up as mine and he can get out and smoke the tires compleatly off of his truck from a stand still with out powerbraking on a 3/4 ton. Now if id try that on my truck id smoke the clutch compleatly out of it or shell out every u joint on the truck. and not even bark the tires.
Originally posted by Bobcat698
RustyJC, here is a better explanation:
If you're both in 2wd the single wheel truck will get more traction on pavement due to its higher pounds per square inch of weight pushing down on the pavement...
With a dually the load is more evenly placed and has less weight on each contact patch of rubber on the ground that will allow them to spin more easily...
On pavement, the rubber conforms to the aggregate irregularities in the asphalt, making the tire-to-pavement connection more similar to a rack (road) and pinion (tire) gear arrangement than the classical physics coefficient-of-friction model. In this case, the shear strength of the rubber and the amount of rubber in contact with the asphalt (i.e., more gear teeth) determine traction. That's why race cars use wide tires/slicks - to get MORE rubber in contact with the road.
Rusty
I do have the anti spin diff, and he does as well. I have driven his truck and pulled with it several times and you can really feel a difference in power between the two. The Cummins has twice the power...
Originally posted by RustyJC
I understand your point completely. If that's true, then why doesn't a top fueler run skinny tires to "get more traction"?
Rusty
Rusty
Originally posted by CTD NUT
You hit it on the head with the coefficient of friction......since it is ultimately the friction that determines traction.
Drag slicks run incredibly soft rubber compounds that create the required friction instead of relying on contact pressure. On a dually, the rubber compound isn't anywhere near soft enough to generate the same coefficient of friction the the single wheel truck achieves by higher contact pressure.
Rusty
All fine and well but what it really amounts to is BLAH BLAH BLAH. Just hook the dang thing up and give it a whurl! If you lose then you know you got same more work to do.
Registered
Something is wrong if you can't bust the rears loose!! If my Comp is on 5x5, I have no trouble peelin' out on pavement with a hard 2nd gear launch and I don't even have big injectors like you. My 2500 hooks up much better and will launch MUCH harder and clearly takes more power to bust the rears free.....but it does do better burn outs since it has so much more power. With the dually you are cutting the contact pressure in half because you doubled the area. Sure, the dually looks intimidating with the 4 rears but don't be fooled - the weight will be much more important in the tug o' war........it is still anyones pull, IMO.
Rusty
You can continue to bother me. I find your posts interesting and educational.....Although I did ok in physics classes, I have not retained as much information as I would have liked. Let them hitch up and pull their trucks apart.....if that is how they have fun, so be it, but I hope you still have some air left in your windbag for those of us who are interested!
sorry, but my dually just wont do it. And dad has a truck just exactly like mine and his wont do that either. Now if i went out and chaned it down and blocked the front tires and had a dd clutch and bullet proof drive train, if i could get em spinning, i could roast em off of there. but just tryin to go out and lay a nice set of black marks, it aint gunna happen.
Registered
Well, it don't get much more heavy duty than a D80, 1410 u-joints and a NV5600.....that is a drivetrain with a lot of beef!.....Let 'er rip!!
Registered
Excuse me. I'll not bother anyone else with my windbag posts. Go hitch it up and get it on.
Rusty
Rusty
