Any tractor pullers here?
Old Aug 23, 2009 | 12:02 AM
deerslayer1979's Avatar
I know a lot of you guys are pulling your trucks, but how about your tractors? We (Dad, my younger bro, and me) went pulling this weekend. We didn't do as good as usual, but I still came away with a 2nd Had alot of fun as always and hoping to get to one more in this season. Anyways post up some pics of you pulling or even of the local pull if you got them.
Heres a couple to start it off...
Me on our 856,
My brother on the "new" to us 756,
DS79
Old Aug 23, 2009 | 12:19 AM
nasty01cummims's Avatar
me and my dad and my brother in law pull. weve got a 45 w-9 that we put a 60 series detroit in. weve got a jd60 and an 806 and a case agri king in the shop that is in the process of a rebuild. ad lets just say that 96mm is gonna fit real good underneath the hood of that case
Old Aug 23, 2009 | 05:56 AM
JD730's Avatar
Here's my John Deere 4430, pulls from 10,500 lbs and up. Didn't run that well with a HX40 on it, but the HX52 really woke it up. Didn't make any other changes.
Old Aug 23, 2009 | 10:20 PM
With that much black smoke you'd have to try real hard to convince me it wasn't turned up Its the wrong color but looks like it hooks pretty good. Was the HX40 stock? or was it something you tried?
DS79
Old Aug 24, 2009 | 06:33 AM
JD730's Avatar
DS79
Its a bit more than just turned up. It was overfueled with the HX40 on it and you could tell, went from 3rd or 4th to 1st or 2nd with the bigger turbo. A schwitzer 3LD or 3LM would have been stock, but they are old tech and too small.
Old Aug 24, 2009 | 10:13 PM
When you said "nothing else" I was thinkng no way that tractor is running stock pump settings.
DS79
Old Aug 25, 2009 | 05:35 AM
JD730's Avatar
DS79
No, I meant we didn't make any other changes, just the turbo switch.
Old Aug 25, 2009 | 08:02 AM
kruegerlouie's Avatar
heres my old rig that I unfortunatly sold,well missed even though its a gasser. was way more of a ride than any pickup,thats fun to though.
Old Aug 25, 2009 | 08:07 AM
how did you get your pic on the post from your photo gallery,It only put the link in for me
Old Aug 25, 2009 | 10:00 AM
JD730's Avatar
Copy the BB code link and paste that in. What did you do to the 800 to get 938 out of it. We still have two G1350's with the D585, one has a factory turbo on it, the other has a hole in the side.
Old Aug 25, 2009 | 12:11 PM
kyncl's Avatar
Here are the tractors the My Dad and I pull. The one with the cage runs on alcohol and the other is a diesel. They are blast to drive!
Attachment 29317
Attachment 29318
Old Aug 25, 2009 | 09:57 PM
Did you ever pull that G1000 down in the SE part of MN? Thats where I am from and I dont know if I have ever seen that one pull down here?
DS79
Old Aug 25, 2009 | 10:23 PM
DS79
once at a moline show,but I changed a carb setting that day and it ran lean. also run it at pepin,wi.
the engine was stock 6"stroke and 5.75" bore and turned 4200rpm
Old Sep 7, 2009 | 10:23 PM
mopower01's Avatar
got quite a few of the ole' minnie mo's as well. the beast is a g-1000 bored .040 over. it's got a p-pump off of a mack semi, drilled out injectors, custom intake and exhaust manifolds, and a hx-55. i'll try to get some pics up tomorrow. the family also pulls with a UB special(propane), za(gas), gb(gas), r(gas), gvi(gas).
Old Sep 11, 2009 | 07:22 AM
JD730's Avatar
Would you care to share some details on putting a P-pump on one? Got a G1350 I'd like to put an A or P-pump on.
