Alvarado TX sled pulls!!
Thought I'd put up the offical thread..Feburary 23 Tractors pull 9:00 AM to around 7:00 PM yes all day not my doing just helping, but if ya want to make a day of it come for all if your comin for truck pulls be there @ 5pm for registration and watch the tractors..
Participans need to be there by 5pm to register and prep there trucks. Oh yah It's going to be a little different this time, everyone will have to pay at the gate and pullers will receive their tech cards at the gate and will pay at the registration table. every one will receive wrist bans, so please wear them so the gate guards will know you have paid...
If I can get the engine together, I should have both G's on the Feb 23rd..
Bryan
I hope to have my M back together by then.....provided it is just a head gasket. Tear down is this weekend. Do any of you guys know if Jeff's turbo alkie tractor is still together? There was another turbo tractor, 560 I think, last year, so I am hoping for a class this year....if we could all stay together for a few pulls we could get some interest.
With the HWH sled.. usually about 50 Antiques.. but I would expect more at the Diamond W... A good drive for you.. but there's an indoor pull (Antiques) in Glen Rose early in Feb.. Not sure if we'll make it to Glen Rose...
Bryan
Bryan
Both?? Is the big G gonna have paint
? My lil M is still in black primer....this cummins swap has tapped the shop time card(wife checks religously) and bank account
I havent hear about Jeff's tractor... (but I got his cell number if you want it.. haha..) Yea.. I got a start on the paint.. at least on the hood.. but wet sanded it through.. so waiting on the weather to warm up to lay some more color...
I set the block back in today... as slow as I am.. I might even have the head on by next week.. haha... (I bet it never blows a cylinder wall again.. hahaa..)
I still think you need to sell it has a hot Antique.. and start on a Alky 560.. or something Green.. haha..
Bryan
Bryan
Bryan
Bryan
(shhhh....dont tell my wife). The 1000+ HP 560's are very intriguing. My brother is working on building one now and he does have a spare chassis, sheet metal, and a couple blocks. However, he is hunting a 301 block because the cylinder walls in the 263's are too thin. My problem at this point is time. I would rather trade for a good 560 with a 301 that I could just do an engine for....maybe Ray Whitney
here are the rules for those who have not seen them yet..All classes 8000 pound maximum unless otherwise noted. See class overviews below:
Work Stock: Stock appearing turbochargers, 1” minimum compression travel on rear suspension, water injection prohibited, hanging weights prohibited.
2.6 Street Diesel: Single turbo, 2.6 inch maximum inducer bore, turbocharger bushings prohibited, 1” minimum compression travel on rear suspension, water injection prohibited, receiver style hitch required, hanging weights permitted.
2.8 Street Diesel: Single turbo, 2.8 inch maximum inducer bore, turbocharger bushings permitted, water injection prohibited, bolt in, removable solid rear suspension bars permitted, receiver style hitch required, drive shaft u-joint shields required, hanging weights permitted.
Super Street Diesel: 3.2-inch maximum inducer bore in twin turbo configuration, unlimited inducer bore single chargers permitted, open driveline permitted, DOT tires required.
Modified Diesel: Unlimited turbocharger, 2 stage maximum, open driveline, open tire, 7600 pound maximum weight.
Changes are to come
we can discuss a heavier work class...
Changes are to come
I really dont understand this open drive line deal!! Someone is gonna get hurt one of these days when one of these trucks chunks a drive line through the floor or u joint pieces into the pullers area or crowd. There should be a minimum requirement of u-joint shields on anything over street stock. The superstock gas trucks require shield and loops and I know there are diesels running alot more power with no saftey equipment at all....
I see....but it is still a concern I have with all the hot diesels. There was one at Stephenville last year that junked the clutch, and from what I understand it put down 1000HP on a chassis dyno two weeks later. The truck did not appear have drive shaft shields when I saw it(I did not crawl under, but they definately were not cased) Trucks like that are cool, but dangerous to the driver and crowd IMO. Is that the 98 in your sig?
Bryan
