1st time puller seeking advice (gear and tire pressure)
i made 3 pulls in 3rd 4LO with a single and they went fine. maybe not the best way but i engaged low 1600-2000 then once i let of of the clutch brought it up. not sure if this would work with all trucks some may have spooling issues at that rpm but mine came up quick.
ive found that 2nd lowrange does the best for me but really not enough wheel speed ______________________________ 97 dodge 12 valve, luk clutch,#10plate ,few screws turned,4in pipe with 5 inch duals at the back
I would say 20 psi maybe lower on the front tires and air the back up as much as is says on the sidewall of the tire like max pressure 60psi thats what I would air the rears up to
I've never pulled a sled, but I've had my truck long enough to figure 3rd/LO would be my choice. 2nd/LO would just be rediculous and I wouldn't think 2/High would have enough gear reduction to not smoke the clutch. But I'm no genious.
Depends on your axle gears, tires, clutch, and power. I run 3.54 gears, 33" tires, and all I ever run is 2nd high. I am looking to switch to 4.10's before next year though.
NavyChief
12-01-2006 11:30 PM
