***Show-me-Smokers*** Houston/Raymondville Mo, Sled Pull May 24th
Old Apr 8, 2008 | 02:27 PM
coreydr2003's Avatar
Show-me-Smokers and MHTTPA are having a pull the 24th of May at the Raymondville Fair grounds east of Houston Missouri. There will be several classes of gas and diesel along with a few tractor classes. Fun starts at 5 pm.
Diesel classes:
2.4 workhorse
2.6 Modified Smoker
3.0 Super Smoker or an Open class, all depending on # of entries
Rules can be found on the Smoker web page@ show-mesmokers.com
Gas and Tractor Classes can be found @ mhttpa.com.
There will be some big prize $$$$ for the diesel classes, and I'll post those numbers soon.
Thanks and I hope we can get alot of you guys to come on out.
Old Apr 13, 2008 | 09:20 PM
Bump****........
Old Apr 13, 2008 | 10:20 PM
satburn's Avatar
I hope to have the truck together by then, if so I look forward to seeing you again Corey.
Old Apr 13, 2008 | 11:22 PM
Kman9090's Avatar
I know you know this all ready but I'll be there if I don't break something major saturday.
Old Apr 14, 2008 | 06:50 AM
Bad-Duvall's Avatar
You goin for sure saterday in bloomsdale?? I will be there my injectors are due in tuesday as long a i dont have any other problems i will be there pulling..
And i will be at there the 24 also..
Old Apr 14, 2008 | 10:20 AM
What are the rules for Bloomsdale?? I dont have my axel loops yet or my air shut off.
Old Apr 14, 2008 | 10:48 AM
Bad-Duvall's Avatar
No need to have air shut off
STREET DIESEL 8500#/ 9000#
Axles, drive train, engine block must be O.E.M
NO Nitrous
NO Water Ijec
Street Driven
Must have licesed and Insurance to match truck
Working suspension ( must be removable)
26" MAX hitch height
D.O.T. 35" MAX tire height (NO altered)
Reese type hitch
WAeight bars allowed (60" MAX center of axle to outside of weight
Traction bars allowed
Stock Frame
Hook Point behind frame rails
2-3/8" diameter bolts "X" pattern behind turbo 12" back or less a muffler
Factory wheel base, andtrack width
Drive shaft loops on rear end
Duals allowed if has a dually bed
1 ton or smaller axles
No Passengers
NO complainingTruck Pull Tech. Committee is in charge of the final decisions on the rules.
OPEN 10,000#
Nitrous is OK
Propane is OK
Super Charger is OK
D.O.T. 37" MAX tire height (NO altered)
Stock frame
Hook point behind frame rails
NO passengers
NO Complaining
Old Apr 14, 2008 | 12:34 PM
Sloverado's Avatar
Small set of towing twins allowed?
Old Apr 14, 2008 | 12:36 PM
Count me out Im rollon on 37'' i could get in the bigger class but Ill make my mind up soon I guess
Old Apr 14, 2008 | 06:28 PM
Kman9090's Avatar
I don't have my drive shaft loops done yet either? I thought you didn't need them for that pull.
Old Apr 14, 2008 | 09:41 PM
blownsmoke2's Avatar
I can't make it to Bloomsdale now! For some reason my sister thinks she should go and graduate that day with a masters degree and my wife and mother think that I should be there. The nerve of those people. Anyway a have all the loops and cross bolts and ect... Maybe somebody should just go take my truck and pull it for me. It was a nice 2ft tall trophy for 1st last spring. Anyhow enough B.S. I really wanted to meet a bunch of you and good luck at the pull. Oh ya by the way Kman don't go and break anything.
Old Apr 14, 2008 | 10:57 PM
Kman9090's Avatar
I'll try not to? Will they not let me pull if I don't have loops?
Old Apr 15, 2008 | 06:37 AM
Bad-Duvall's Avatar
One time pull if you dont.. But the next time you want to pull will the river hills tractor club you must have them..
Old Apr 15, 2008 | 06:38 AM
Bad-Duvall's Avatar
Ill pull it for you.. No problem
Old May 4, 2008 | 08:04 AM
Bump......
