Sponsored by: CARiD
Commonly used acronyms and terms
Old Mar 2, 2010 | 04:29 PM
lgp9999's Avatar
12v - The 12 valve variant of the Cummins Turbo Diesel, consisting of 1 intake valve and 1 exhaust valve per cylinder. The 12v can be found in Dodge pickups from '89 until early '98 model year.
24v - The 24 valve variant of the Cummins Turbo Diesel, consisting of 2 intake valves and 2 exhaust valves per cylinder. The 24v can be found in Dodge Pickups from mid '98 until present.
3kGSK - 3000 RPM Governor Spring Kit
4BT - 4 cylinder, B series, turbo. This is a 3.3L or 3.9L 4 cylinder version of the engine found in the Dodge pickups. These are popular for retrofitting into other vehicles as they share the same torquey and reliable characteristics as the larger 6BT, but without the size and weight which allows them to be transplanted into a wider variety of applications with less modification.
4kGSK - 4000 RPM Governor Spring Kit
5.9 - Dodge pickups from '89 into '07 were 5.9L inline 6 cylinder engines.
6.7 - Dodge pickups from mid '07 to present are 6.7L inline 6 cylinder engines.
6BT - 6 cylinder, B series, turbo. This is the 12 valve engine found in '89 - '98 Dodge pickups.
ABS - Anti lock braking system
AFC - Aneroid Fuel Control. Controls off-boost fueling in order to minimize black smoke prior to the turbo spooling
APPS - Accelator Pedal Position Sensor
BDC - Bottom Dead Center, usually referring to cylinder number 1, is when the piston is at its bottom most point in the stroke.
BHAF - Big Honkin' Air Filter
BOMB - Better Off Modified Baby!
BUMP - Bring Up My Post
CDL - Commercial Driver's License
CEL - Check Engine Light
CPS - Crank Position Sensor
CR - Common Rail, where the injection pump pressurizes a fuel rail that all injectors are connected to, and the ECU tells the injectors when to fire, as opposed to the more traditional diesels that have an injection pump that also acts as a fuel distributor. CTDs in Dodge Pickups starting in '03 were all CR.
CSS - Crank Speed Sensor
CTD - Cummins Turbo Diesel
DRW - Dual Rear Wheel, a.k.a. Dually
DTR - Diesel Truck Resource, a.k.a. the site you're currently looking at
ECM - Engine Control Module
ECU - Engine Control Unit
EGR - Exhaust Gas Recirculation
EGT - Exhaust Gas Temperature
G56 - The 6 speed manual transmission found in CTDs after mid '05
GAWR - Gross Axle Weight Rating. The weight capacity of an axle.
Getrag - The 5 speed manual transmission found in the 1st generation CTD
GCWR - Gross Combined Weight Rating. This is the maximum combined weight of the truck, any contents including passengers, the trailer, and the total weight of the loaded trailer.
Grail - The Holy Grail of trucks. This means different things to different people, although it is usually a '98 12v, often with a manual transmission, sometimes with a short bed.
GVWR - Gross Vehicle Weight Rating. The GVWR includes the net weight of the vehicle, plus the weight of passengers, fuel, cargo, and any accessories added to the vehicle after purchase. The GVWR is a safety standard used to prevent overloading.
GSK - Governor Spring Kit. Inside the Bosch P7100 injection pump there are governor springs that limit maximum RPM by working against centrifugal weights. Stiffer springs hold the weights inward until a higher RPM, thus raising the RPM governor of the truck.
IFS - Independent Front Suspension
IRS - Independent Rear Suspension
ISB - 24 valve CTD
KDP - Killer Dowell Pin
LWB - Long wheel base, referring to an extended cab truck with a long bed
NV4500 - the 5 speed manual transmission found in CTDs beginning in '94
NV5600 - the 6 speed manual transmission found in CTDs from '99 until mid '05
OP - Original Poster
P-pump - A "street term" so to speak, for the Bosch P7100 injection pump
P7100 - the Bosch built inline injection pump found on '94-'98 12v CTDs.
PCM - Powertrain Control module
PSD - Powerstroke Diesel
RWAL - Rear Wheel Anti Lock Brakes
TC - Torque Converter
SBC - South Bend Clutch
SWB - Short wheel base, referring to either a truck with a regular cab and long bed, or an extended cab and short bed.
TDC - Top Dead Center, usually referring to cylinder number 1, is when the piston is at its highest point in its stroke.
TPS - Throttle Position sensor
VE - The Bosch built injection pump found on CTDs from '89-'93
VP44 - The Bosch built injection pump found in 24v CTDs from '98 through '02.
VSS - Vehicle Speed Sensor
WOT - Wide Open Throttle
Old Mar 2, 2010 | 05:03 PM
SIXSLUG's Avatar
Don't forget some of the others like:
IMO - In My Opinion
ROTFLMAO- Rolling On The Floor Laughing My Butt Off
FWIW- For What Its Worth
IIRC-If I Remember Correctly
IMHO- In My Humble Opinion
AFAIK- As Far As I Know
WVO- Waste Vegetable Oil
WEO- Waste Engine Oil
for a few more!
Old Mar 2, 2010 | 07:14 PM
txarrowhunter's Avatar
SRW- single rear wheel (3500)
QCLB - quad cab long bed
QCSB- quad cab short bed
MCLB- mega cab long bed
MCSB- mega cab short bed
C&C -cab and chassis
#2 diesel
Old Mar 2, 2010 | 08:38 PM
Blake Clark's Avatar
lg great job on the list.
Here are a couple more.
CAI - Cold Air Intake
DPF - Diesel Particulate Filter
NOX - NO2 (Oxides of Nitrogen) Catalyst
CAT (Kitty) - Catalytic Converter
EPA - Eternal Pain in
Old Mar 2, 2010 | 08:51 PM
cincydiesel's Avatar
Always thought IMHO was In my honest opinion?
Learn something new everyday
Old Mar 2, 2010 | 08:58 PM
madhat's Avatar
Administrator/Jarhead
Either or...
Probably, I'm going to cut and paste all of this info in the first post...
Old Mar 2, 2010 | 09:39 PM
bansh-eman's Avatar
TBN - Total Base Number
Old Mar 2, 2010 | 10:36 PM
Red3quarter's Avatar
RCLB - regular cab long bed
WMO - Waste Motor Oil
Bio - short for Biodiesel
B20, B50, B100 ect...- refers to the percentages of biodiesel
Old Mar 3, 2010 | 12:42 PM
DevilzTower's Avatar
for the getrag = also ... 'rag and G360
BTW ... I guess that's one too --- By the way
Great idea on the thread ... definitely will help folks, learning all this terminology when I first started reading DTR was like learning another language
Old Mar 3, 2010 | 12:46 PM
ssandlin's Avatar
LSD - Low Sulfur Diesel Fuel, 500 ppm or less (not to be used in the 6.7)
ULSD - Ultra Low Sulfur Diesel Fuel, 15ppm or less, can be used in the 5.9 and 6.7
Old Mar 12, 2010 | 02:07 AM
pulltilbroke's Avatar
Best Paint (Getrag category)
CP3- Injection pump found on 03-current Cummins Dodge trucks
ext cab- self explanitory
std cab-
Old Aug 30, 2010 | 06:52 AM
hhrumph's Avatar
SS= Steady State
Old Jan 5, 2011 | 07:20 PM
SIXSLUG's Avatar
A smarty college kid told me the other day that an acronym makes a word i.e. BOMB, BUMP, etc.
What we mainly use are known as initialisms, which do not make a pronouncable word.
JAHU
Old Jan 22, 2011 | 02:51 PM
Gatorama's Avatar
MLA-Multi Letter Acronym
Old Sep 20, 2011 | 07:56 AM
Hvytrkmech's Avatar
ESS, engine speed sensor, usually a crank sensor, but in some applications it could be a cam sensor.
