Cable Corrosion/new battery/terminal config?
My Positive cable keeps corroding at the post. I need a total replacement, and I need a way to get rid of the octopus of wires connected to the little factory terminal that seem to be adding up over time. Where can I get a good Cable harness and terminals and how do I stop the corrosion?
It usually depends on what brand of battery you are using. For example, the Mopar replacement batteries are nasty leaky sweaty things that constantly corrode the connections and hold-downs. There are other brands, like NAPA, that don't seem to leak and cause corrosion nearly as much. If you want to eliminate the problem altogether, you can go with an AGM battery like an Optima. Many on here swear by them.
Autolite, platinum. You know how it goes, battery dies, you need replacement batteries fast so you go to the nearest store so you can get on the road. I might switch to optima next time round though.
AGM batteries pretty much eliminated my corrosion problems.
Have a look at www.custombatterycables.com - they have everything you need to replace your cable (they will even make it for you).
With all the problems we have with our trucks and electrical system, you might want to check terminal voltage at the battery. You also might also want to keep close tabs on the water usage of the battery. If you have to replace water often than is generally a vindication of lower charging ritual cause corrosion.
Dr. Fricking evil: Those cables are not up for sale at this time, he says he can't fulfill any more orders this year. Maybe I'll try again next year, after all they still work fine, just getting ugly. I'll check the water, once I topped em off, but didn't need to, but I'll keep my eye out.
Goldenbear
Jan 7, 2005 11:17 AM
