Big Rigs Talk about other Cummins powered vehicles here. As a matter of fact, it doesn't even have to be Cummins, but it will be diesel! :)
Parking brake question
Old Jul 30, 2009 | 08:00 PM
Stamey's Avatar
As I have been learning more about air brakes I have read that you should not operate the service brake when the parking brake is on if you have S-cam brakes. Apparently it can damage the parking brake mechanism.
I don't understand why the design would be this way since you would be expected to be operating the service brake when you engage or release the parking brake, so you don't roll.
Can someone explain this to me?
Thanks,
Chris
Old Jul 30, 2009 | 08:55 PM
DmaxEter's Avatar
When the parking brake is applied, there is a giant heavy spring in the brake chamber that is pushing aginst the slack adjuster which is twisting the s-cam and it is spreading the shoes out to the drum. When that spring is pushing on the slack adjuster and you push the service brake with a decent amount of force it is just putting twice or three times the normal pressure on the slack adjuster and its internals. I have never seen any damage caused to any of the compnents due to someone doing this but thats the theory or at least what I was taught.
Old Aug 2, 2009 | 10:24 PM
Nick02Ram's Avatar
I've never seen it hurt anything, either. But you're not supposed to do it. That huge spring (I have a crooked middle finger b/c of it) on top of 70-90 psi exerts a lot on the brake system, but I've never seen any damage, I could possibly see premature cam bushing wear maybe.
Old Aug 2, 2009 | 11:00 PM
1-5-3-6-2-4's Avatar
theres a valve in modern trucks thats prevents over pressure. from service application while chamber is dynamited. but you still shouldn't do it/.
Old Aug 15, 2009 | 10:52 AM
dieselcamp's Avatar
Newer trucks (last 20 years or so) most have anticompounding valves so when the spring brake is applied and you use the service brake it wont feed air to the service of the brake chamber. Dose this with a signal line frome the pp valve.
Old Aug 15, 2009 | 12:53 PM
Nick02Ram's Avatar
Yeah, i dunno how I didn't think of that. I replace em quite frequently, also have to bypass the anti-compound part of the valve once ina while on the side of the road. The SR-4's I think it is, get bypassed all the time.
Old Aug 18, 2009 | 08:58 PM
Stamey's Avatar
Well I was wondering because my 1986 IH S1900 gets parked on a hill, and when I am releasing or engaging the parking brakes I always have my foot on the service brakes to prevent unwanted roll, especially since I imagine it is not the best idea to engage the parking brakes while the truck is in motion.
Thanks,
Chris
Old Sep 4, 2009 | 10:42 AM
94ram's Avatar
its been said that all that extra pressure is enough to break the shoes. i always let off right before applying the parking brake or hop on it right after releasing it.
Old Nov 3, 2009 | 05:41 PM
shorthair's Avatar
For the past 30+ years I've applied the service brakes before releasing the Maxi's but as I only apply 10-20#'s nothing has broke yet. Even when running Diamlers test beds we didn't have any problems but if you are parked on a hill so steep that you have to apply more than 2-# then I suggest you are parking in the wrong place.
Old Nov 21, 2009 | 11:21 PM
Clayten's Avatar
DTR's Toad Wrangler
Ya that is a for sure
cromulius
Jan 24, 2013 12:08 AM
mtb1982
Dec 10, 2011 11:15 PM
seveninc
Jun 14, 2010 08:38 PM
bulldog_bones
Sep 9, 2009 01:53 PM
highcountry
Jan 6, 2007 09:34 AM
