Big Rigs Talk about other Cummins powered vehicles here. As a matter of fact, it doesn't even have to be Cummins, but it will be diesel! :)
Kitty Cat?
Old Mar 18, 2010 | 09:32 PM
LUKE-MM-PULLER's Avatar
Kitty Cat?
My daily driver has a C12 in it with 536K on it I had new bearings rolled in at 513K and on the first oil change it started using a gallon of oil to every 1500 miles, so I changed the oil and 9000 miles in to it, it hasn't used a drop. So does anybody have any suggestions as to why this little miracle has happened? Both oil changes have been done with Rotella.
Old Mar 18, 2010 | 09:40 PM
On another note I learned don't ever put 5" dual straights on a C12, Darn truck will make you sick to your stomach after 12-14 hours a day LITERALY!
Old Mar 19, 2010 | 12:07 AM
Russ Roth's Avatar
Not sure I have an answer but I drive a C15 Cat that will go through a gallon pretty quickly when it's time for an oil change. After the change I can go for a month or more before adding.
Old Mar 22, 2010 | 08:24 AM
Nick02Ram's Avatar
We've had some Cummins with the opposite problem, we'd do an oil change , and in one trip it would lose a gallon, but never another drop after that. Noone has really been able to explain it.
Old Mar 22, 2010 | 07:57 PM
The Tank's Avatar
5in straights on a c12 is LOUD lol i know drove a dump truck with that
Old Mar 22, 2010 | 08:37 PM
I'm startin to get used to them, but i wouldnt do it twice!
Old Mar 24, 2010 | 09:40 AM
Russ Roth's Avatar
Originally Posted by Nick02Ram
We've had some Cummins with the opposite problem, we'd do an oil change , and in one trip it would lose a gallon, but never another drop after that. No one has really been able to explain it.
I've been around a lot of different rigs over the years and I've seen that happen, too. Some of them seem to want to just run a gallon low for some reason.
Old Mar 24, 2010 | 08:28 PM
pevaguy's Avatar
Oil consumption
I've seen a lot of engines that will not stay on the "full" mark. I tell my customers with engines having 8 to 11 gal. capacity to wait til the level drops to the "add" mark, then add a gallon. Many engines will loose a couple of quarts then stabilize at the level it likes to run at. If you try to keep it on the full mark, it will use oil steadily.
Old Mar 25, 2010 | 08:14 PM
That is my experience as well.
Old Mar 26, 2010 | 01:36 AM
1-5-3-6-2-4's Avatar
agreed there. anywhere in the range is acceptable operating level. let it run where it likes to run. but obviously not if it goes below minimum.
Old Mar 26, 2010 | 08:43 AM
DieselDaze's Avatar
Are you really getting use to them or just slowly going deaf?
Old Mar 26, 2010 | 05:32 PM
What did you say I couldn't hear you. Well that issue is up for debate.
Old Mar 30, 2010 | 10:27 PM
dieselcamp's Avatar
Thay want to run a gallon low because the dip stick needs to be calibrated. Common practice for CAT engines, usually done the first oil change. There are many service letters on CAT SIS web.
Old Mar 31, 2010 | 01:46 AM
Russ Roth's Avatar
While I currently drive a Cat, I have been around a lot more Cummins and Mack engines. Some of those like to run on the low side also.
Old Apr 17, 2010 | 06:53 AM
RollinCoalSmoke's Avatar
One of my 3406-B models will not stay full, If you leave it a gallon low it won't use any oil for app.12,000 miles. It's not unusal for these big engines to do this.
tanderson2002us
Nov 9, 2007 11:32 PM
GMScott
17
Aug 29, 2006 11:02 PM
Nov 26, 2002 10:59 AM
