Big Rigs Talk about other Cummins powered vehicles here. As a matter of fact, it doesn't even have to be Cummins, but it will be diesel! :)
Jakes
Old Jul 20, 2009 | 09:37 PM
terl00's Avatar
Jakes
Hey guys, I need help. I got a 99 Frieghtliner FL 80, it has a 3126 cat (300 hp)- with a eaton-fuller 9 spd-- I was wandering if jakes can be installed on this truck,, wander what it would cost...
Old Jul 20, 2009 | 09:44 PM
Number47's Avatar
i think so but i cant help with cost. i just dont know. you would need the valve cover(s) the jakes and wiring harness, and dash switches. I would imagine the engine harness has the plug but you would have to have it activated in the engine computer
Old Jul 21, 2009 | 06:27 AM
You can't put a real jake brake on it, but you can install an exhaust brake. I pestered management until they put one on my work truck (same motor as yours but in a Sterling tandem axle w/10 speed) and it made a huge difference. Downshifting slows you down instead of just making the engine noisier.
The Pacbrake PXRB is a good one. It works better at low RPM than the older orifice type brakes, but it wasn't around back when I got mine.
You can do the bolt together, plumbing, and electrical yourself but you need a shop to reprogram the ECM. Have the shop that flashes the ECM enable fan braking too, the fan does almost as much as the exhaust brake. I think installed cost was a little under $2k - but if it saves one brake job over the life of the truck it's pretty much paid for itself. I got 95k out of my last set of rear brakes, which is pretty good in local P&D service.
Old Jul 21, 2009 | 02:03 PM
rich's Avatar
go to the jacobs web site it will tell you if they make one for that motor
Old Jul 21, 2009 | 07:05 PM
Brian08Q35004x4's Avatar
From: This Nazi state of California 2nd home Gilbert AZ under God
Here is your application data:
Engine Manufacturer: Caterpillar
Engine: 3126
Engine Serial Number Prefix: All
Horsepower: All, vehicle has air supply
Engine Brake Model Number: EX3116/3126
Old Jul 21, 2009 | 07:18 PM
2500's Avatar
all diesels can have an exhaust brake installed. basically an exhaust brake adds a way to slow down flow of exhaust gases.
brake is either an inline or clamped on to turbo housing. within brake will be a butterfly valve controlled either by vacuum or air pressure servo. which is in turn controlled by a electric selenoid.
so basically one wire controls solenoid's function. this control wire can be feed to an ECM or a series of switches to clutch/fuel pump/accelerator pedal/etc.
for a manual tranny... clutch has to be engage with no fuel entering engine before exhaust brake can engage.
certain diesel engines require installation of stronger exhaust springs to keep valves from floating.
Old Jul 22, 2009 | 06:31 PM
bigdave's Avatar
Yes, but there is a big difference in an exhaust brake and what everyone calls a "Jake Brake".
Old Jul 23, 2009 | 09:48 AM
rich's Avatar
jake uses the actuall engine cylinders for braking where the exhaust doesnt, hence it is called an engine brake
Old Aug 15, 2009 | 10:56 AM
dieselcamp's Avatar
Jake Brake is an engine compression brake that operates the exhaust valves and decompresses the engine absorbing power. Exhaust brake just adds exhaust back pressure so the cylinder does not scavenge completely and that absorbs power.
Old Aug 15, 2009 | 11:27 AM
RollOver Pete's Avatar
I installed a Blue OX Exhaust Brake on a 3406B.
Price shipped to my door was under $1000.00 and it took about 4 hrs for me to do the install. No doubt the best $1000.00 I've spent on the truck.
http://www.brakesystemsinc.com/blueox.html
Old Aug 18, 2009 | 10:20 PM
dieselcamp's Avatar
In stall the trigger jake heads on there along with the exhaust brake and you will like that too.
If you don't already have them.
