Big Rigs Talk about other Cummins powered vehicles here. As a matter of fact, it doesn't even have to be Cummins, but it will be diesel! :)
Lug nut bolt pattern on big trucks?
Old 10-16-2013, 02:40 PM
6cylinders's Avatar
IS there a lot of different lug nut patterns on big rigs?
I have an old single axle trailer, home built, that has 9.00 x 20 tires on it,
split rims, military surplus I think.
How hard is it going to be to replace these wheels/tires with something
more modern.
SIze, height, width does not matter, plenty of room on this old trailer, used only on OFF ROAD private property .
Old 10-18-2013, 07:45 AM
bjytech's Avatar
There are not to many different bolt patterns on big rigs.
If its stud piloted these patterns are used in the US:
6 hole, 8-3/4 inch
10 hole, 8-3/4 inch
10 hole, 11-1/4 inch
10 hole, 13-3/16 inch
If its hub piloted these patterns are used in the US:
6 hole, 8-3/4 inch
10 hole, 8-3/4 inch
8 hole, 275 mm
10 hole, 285.75 mm
Old 10-18-2013, 10:49 AM
6cylinders's Avatar
Good info, thanks.
Old 07-27-2014, 05:52 AM
1-5-3-6-2-4's Avatar
10 on 225mm for the superduty cab and chassis trucks also.
Old 07-31-2014, 02:39 AM
Hvytrkmech's Avatar
Yeah, for the toy trucks......
wisconative
05-13-2013 07:20 AM
jerry007
01-08-2009 06:29 PM
silkywoods
03-14-2008 05:57 PM
lt11le
03-14-2005 12:36 PM
Jmac
09-04-2004 01:13 PM
Quick Reply: Lug nut bolt pattern on big trucks?
