? about Band Adjustment
Old Apr 7, 2010 | 08:52 AM
CUM4X4MINS's Avatar
In these instructions I want to make sure I understand the amount of turns to back the adjustment screw off by. Is it 1 and 3/4 turns or 1 to 3/4 turns?
The front (kickdown) band adjusting screw (2) is located on the left side of the transmission case above the manual valve and throttle valve levers.
1. Raise vehicle.
2. Loosen band adjusting screw locknut. Then back locknut (1) off 3-5 turns. Be sure adjusting screw turns freely in case. Apply lubricant to screw threads if necessary.
3. Tighten band adjusting screw to 8 N·m (72 in. lbs.) torque with an appropriate Torx™ socket.
CAUTION: If Adapter C-3705 is needed to reach the adjusting screw, tighten the screw to only 5 N·m (47-50 in. lbs.) torque.
4. Back off front band adjusting screw 1-3/4 turns, for diesel vehicles, or 1-1/2 turns, for V-10 vehicles.
5. Hold adjuster screw in position and tighten locknut to 34 bN·m (25 ft. lbs.) torque.
6. Lower vehicle.
Michael
Old Apr 7, 2010 | 10:02 AM
CUM4X4MINS's Avatar
Why did my post get moved? This is something that I need help with right now as in an emergency.......I am in the middle of working on my truck and need help ASAP.
Michael
Old Apr 7, 2010 | 10:22 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
It was moved here in the hopes of getting you a quicker reply
Old Apr 7, 2010 | 10:43 AM
CUM4X4MINS's Avatar
O alright thanks Lary. Well would you like me to delete my second post that I made in the Emergency Help section?
Michael
Old Apr 7, 2010 | 12:12 PM
justme-'s Avatar
to answer the question- it is 1 AND 3/4....how does 1 to 3/4 turns make any sense?
A range of turn would not make sense either- (and would be listed as 3/4 to 1 turn, not 1 to 3/4 turns) too much variation in a range of turning for a band adjustment.
Old Apr 7, 2010 | 12:34 PM
CUM4X4MINS's Avatar
It doesn't really but I just wanted to get it right you know..Thanks for the help.
Michael
Old Apr 7, 2010 | 01:05 PM
JJPage's Avatar
I just spoke with Bill@DTT on Monday, he specified backing off the front band adjustment two turns.
There seems to be a discrepency between the OM and builders, why would this be?
EDIT: Bill did say to warm it up first, "put some heat in it", is what he said.
Old Apr 7, 2010 | 10:56 PM
alboy's Avatar
Use a marking pen on the adjustment screw, makes it easier to see how much you have tightened it.
Old Apr 9, 2010 | 11:25 AM
justme-'s Avatar
well, if you have a trans from that builder I would go with his recommendations, but if it's stock go with factory. Not sure why a difference unless he uses different bands (thicker?) My builder adjusts to stock when I bring it in fwiw and it's not a stock trans.
betsycam
Sep 26, 2004 03:44 AM
miketriton
Aug 20, 2004 01:14 PM
Outlaw02
Jul 8, 2004 10:16 PM
vtailflyer
Feb 1, 2004 06:43 PM
Dodgezilla
May 6, 2003 06:50 AM
