whats it worth
Old Mar 19, 2009 | 10:17 PM
winkdemon's Avatar
whats it worth
i found a 1997 cummins engine 400 ish on it , had bad oil leak and was pulled and they found pits in camshaft when fixing oil leaks , engine is all there down to the turbo , ????????????????????????????????????
Old Mar 19, 2009 | 10:29 PM
cLAYH's Avatar
$2000 at MOST if the body is good. Remember the engine maybe HD but the rest of the truck is still just a light duty truck. I'assuming the engine is still all torn down?
Old Mar 19, 2009 | 10:31 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
I'm not to sure but found this ad for a 95 diesel for $2800....
http://calgary.kijiji.ca/c-cars-vehi...AdIdZ111295835
Old Mar 19, 2009 | 10:34 PM
Mike Holmen's Avatar
The Guru
Is it in pieces? Ouch, thats gonna be a hard sell. I would pass on the truck unless you have part available. I would say $500, as is. If the guy takes it, you get a bag of bolts and go for it. If not walk away. There always more trucks.
Old Mar 19, 2009 | 10:36 PM
winkdemon's Avatar
the engine is back together , but i only want the injection system off it , i think i can have it for a 1000
Old Mar 19, 2009 | 10:38 PM
winkdemon's Avatar
i talk to the guy he said the truck is as is , will not gaurentee it's good engine
Old Mar 19, 2009 | 10:41 PM
winkdemon's Avatar
and it just the engine , i just need the injection system to take my ve to p-pump
Old Mar 19, 2009 | 10:43 PM
Mocho's Avatar
That seems pricy. Was not long ago a 94 2500 400km 5spd 2wd perfect running order pretty good shape $2000. If I had the room it would be in my driveway right now!
Old Mar 19, 2009 | 10:44 PM
The Guru
I have that VE engine if you want parts. One piston is messed up. Between the two of them you should almost have a runner. Just buy it cheap. It can't be worth much. Take $750, cash. You might get lucky.
Old Mar 19, 2009 | 10:53 PM
winkdemon's Avatar
ya i will hold off and see if truck comes along
Old Mar 19, 2009 | 10:55 PM
winkdemon's Avatar
all i need is the p-pump stuff to change on to my ve my ve only has 150 000km on it from when i put pistons and bearings in it
Old Mar 20, 2009 | 03:26 AM
Tate's Avatar
$1k really isn't that bad. Try and find a good running pump for that, let alone the rest of the parts to convert. You could do better, but not that much better. I'd consider it if I were in your shoes. A kit to do what you are wanting to do is $1800 from Haisley/Scheids, and you still need a variety of items.
Old Mar 20, 2009 | 06:31 PM
winkdemon's Avatar
well i think i am going to wait abit and see if i can find a hole truck ,
OldSmokey
Apr 2, 2005 10:57 PM
2manykids
Dec 27, 2004 03:12 PM
Scubasteve
Dec 24, 2004 09:48 AM
May 26, 2003 11:45 PM
midwestdually
May 19, 2003 09:25 PM
