Small pnuematic valves
Old Sep 29, 2010 | 05:39 PM
  #31
Dr. Evil's Avatar
Sorry Tate - have been busy with work.
I would try a Mac 45A-AA1-RA11 - http://www.macvalves.com/products/Fo...mall/45/45.htm
http://www.macvalves.com/products/Fo...mall/45/45.pdf
These typically have 1/8" npt ports and Im not sure how it will hold up with the temps your dealing with. I may be able to get my hands on one.
Old Sep 29, 2010 | 05:48 PM
  #32
Tate's Avatar
Thanks Shane, but those are still solenoid operated. I was after pilot operated, so purely on pressure. I've decided to go a different, much simpler route. Just need to actually do it now.
Old Sep 29, 2010 | 06:39 PM
  #33
cbrahs's Avatar
Originally Posted by Tate
Anyone know of a place to pick up a small 3/2 pilot operated valve? Looking for the pilot pressures to act on both sides. Instead of explaining it, I made a picture. I just want something like this, adjustable spring pressure, and nice and small. You instrumentation guys (Shane) might have a lead on these. Oh, and cheap would be nice.
I have not read all the posts but when I was on the Top Fuel team, our fuel and clutch management system was built by a guy named Bob Auto.
I think the air valves he uses are close to what you may need. I searched for his website but it still shows under construction but call him up. Very nice guy but a GENIUS and may get way detailed on you but cool to talk to.
Automan Technologies
362 Sacramento Street
Auburn, CA 95603
Phone/Fax: 530-885-8815
Old Sep 29, 2010 | 07:47 PM
  #34
Dr. Evil's Avatar
No its pilot operated pressure only with a spring return.
A few of those are electrically operated but not the p/n I gave you.
Old Oct 4, 2010 | 10:35 AM
  #35
Mike Holmen's Avatar
The Guru
Tate, just thought of this, you could install a wastegate onto the cold air pressurized tube. The tube going from turbo to IC, you could just use pressure across the IC to open the gate. I don't know how big of gate I would run, but it should work. You can dial in one of those gate pretty easy. I would use one those 4psi spring inside, air horn pressure into bottom and turbocharger air pressure on top. A little trial and error I bet it would remove the turbo barking. It would only take 1/2hr to 1 hr build a pipe.
CruisingRam
Jan 19, 2012 04:45 PM
pappygtb
Aug 28, 2003 12:30 AM
yrusoslow2
Feb 19, 2003 09:24 AM
KwikKurt
Jan 30, 2003 01:58 PM
rattle_rattle
Nov 12, 2002 10:38 PM
