Shifter slack issues
Old Feb 13, 2009 | 08:43 PM
greenworks's Avatar
OK got the new short shift kit put it in and the shifter when not in my hand falls to the far left in nuetral and if you grab it and move it around it is very sloppy. It does the same with the stock shifter in as well to eliminate the new short shift kit. I have taken it aprt 5 times but can't figure it out unless I dropped something. I think before if I pulled the shifter to the nuetral poistion it would pull back the the center of that position. on top of that my Dodge DVD manual is corrupt so I can't check a exploded view of the 5 speed shift tower.
Any suggestions
J
Old Feb 13, 2009 | 09:31 PM
Tate's Avatar
Its been a while since I have taken one apart, so its all by memory at this point. One the pivot shafts on the shifter handle (goes side to side), there are the black plastic seats, that would press against a plastic ring or spring. If one of those plastic seats were to fall out, it would want to lean in that direction. So my guess is that you missed one of those plastic seats that go onto the handle.
BTW, no exploded views in the 01 FSM, otherwise it would have made it much easier for my to explain what I am thinking.
Old Feb 13, 2009 | 09:54 PM
greenworks's Avatar
Tate if the truck was on a hill with the passenger wheels in a low spot the shifter would fall to the right as well its just the natural way the shifter is bent it falls tot he left as it sits normally.. I can littlery blow on the shifter and it will move back and forth. I have read alot tonight and one site was talking about nuetral plunger springs, but it has to be something with the tower as it was fine before the shifter snapped.
Old Feb 13, 2009 | 10:42 PM
greenworks's Avatar
this is my shift tower
Old Feb 14, 2009 | 12:35 AM
Tate's Avatar
You migt be missing both seats on that shaft then. If you take the tower apart and post a pic, I can show you what I'm talking about.
Old Feb 14, 2009 | 09:25 AM
greenworks's Avatar
I assume you are talking about the black square pieces that fit on the sides of the shifter. If so those are in there.
Old Feb 14, 2009 | 05:11 PM
Tate's Avatar
Yep, those were what I was talking about.
Old Feb 14, 2009 | 11:02 PM
Mike Holmen's Avatar
The Guru
Greenworks, just put in an auto tranny. Then you just put foot on floor and watch and wave as you pass people.
Old Feb 15, 2009 | 04:46 PM
greenworks's Avatar
I figured it out today guys thank for the help, back to normal
Old Feb 17, 2009 | 11:12 AM
Lil Dog's Avatar
What was the problem J?
Old Feb 17, 2009 | 11:29 AM
Dr. Evil's Avatar
I think I know
Old Feb 17, 2009 | 01:30 PM
greenworks's Avatar
me.....
remember that song by Travis Tritt a few years ago "here's your sign" well....
I just wasn't thinking right and had the plate that holds everything together upside down and being that it fit well I was trying everyhting that I could to other things to get it to work.I gave myself a stern talking to after I figured it out
J
Old Feb 17, 2009 | 10:43 PM
Lil Dog's Avatar
Hey, sounds alot like me... Good you got it figured..
tyssniffen
Feb 12, 2006 03:20 PM
epenn03
Dec 2, 2005 07:19 AM
wannadiesel
Sep 21, 2004 07:04 AM
Lambo
May 21, 2004 10:14 PM
INsIdious
Apr 8, 2004 06:56 PM
