new turbo finally made it here
Keep us posted. I had a tip rub on start-up from a compressor impeller. If the turbo is loose and you put some stress (twisting forces) onto the turbo (exhaust system/cold air tubing), you could get some turbine blade rubbing. You'll just lose efficence of the turbocharger.
But, If the shaft to bearing is tight, send the turbo back. Take off the compressor shroud and do a hand spin test. If the bearing is tight now, after 50000km, it will just get worse from the carboning/heat. You'll have to let the engine cool down more than typical to prevent it from happing.
Good luck
Good luck
v-bar
Jun 22, 2003 10:27 AM
Dieseldude4x4
Dec 23, 2002 08:56 PM
Dieseldude4x4
Oct 17, 2002 04:58 PM
