June Dyno Dayz In Red Deer???
Old May 3, 2008 | 10:40 AM
  #106
1-5-3-6-2-4's Avatar
Theres currently a track 10 minutes from my house..........I can see more racing than sled pulling happening.
Old May 3, 2008 | 01:59 PM
  #107
Tate's Avatar
Originally Posted by kennyblatz
went with the 82 cause he said if i end up with to much fuel i can upgrade to the 88 for about 300 bucks. 50 - 56 trim i don't even now what that relates to
tate when did you get a 98 12v?
The trim relates to the area of the exducer to the area of the inducer. If you have the stage two like me, its the .56 trim. They are both 82mm exducer. Square that, multiply by the trim (0.56), then square root and you get the inducer size. The 1 is in the 59mm range, the 2 is in the 61mm range. Did you pick that turbo up from Tom?
I picked up the 12v yesterday. Need to get it registered, do an oil and fuel filter change, and I'll need some advice from the 12v gurus. I've got a lift pump tick. No fuel pressure gauge yet, so I don't know if someone stretched the overflow valve spring too much, or if its just a lame pump.
Old May 3, 2008 | 06:52 PM
  #108
kennyblatz's Avatar
yeah turbo was from tom its the stage 2, said he had this one that was on a truck for about 5k so it was a little cheaper. thats sweet if you want a little better clutch for the mean time let me know i'll have this luk out soon i hope,
Old May 3, 2008 | 07:15 PM
  #109
kennyblatz's Avatar
trying the picture thing, had some old tires around...
Old May 4, 2008 | 03:35 AM
  #110
Tate's Avatar
Does it have the HX40 outlet on it, or is it the Garrett adapter? Good that you picked it up. I'll want a ride in your rig when you get it on, I'm quite anxious to see how it performs.
I'm sure I'll need a clutch soon. I'm getting the itch to put a 3k GSK, my hot rod 370 injectors and a 10 plate in. This thing is a dog with the stock governor springs. Feels like a Smarty on half power. The pedals are opposite to my dually. Light clutch and hard throttle. Used to a real stiff clutch and sensitive throttle.
Old May 4, 2008 | 11:00 AM
  #111
Mike Holmen's Avatar
The Guru
I just want to point out, 3782 garrett makes a nice secondary twins turbo. Put a S400 under it, you'll flow more than enough air for any fuel combo you can dream of. I would guess that you would have air to support 700 to 800rwhp, of course if you want to use NOS, you don't need the S400. I'm trying to find a spot to fit in my methanol kit. I might have to use the window washer bottle for this outting. I wonder how the wastegate is set-up? Stock it starts to opens around 40psi area, I currently have mine set to fully open at 35psi. I have extra 3in exhaust flanges made up for the garrett if you want to try welding as I think that the garrett stock 2 1/2 exhaust flange, I cut mine off and dumped the rest. I would like to see how Tate's 4in flange is built.
Old May 4, 2008 | 07:36 PM
  #112
kennyblatz's Avatar
i got a hx 40 downpipe from tom and the flange is on the turbo tom has them made up for all of his that he sells.
yes twins would be sweet but people keep telling me about thing called an investment, i might have to buy a house soon.
Old May 5, 2008 | 07:10 PM
  #113
The Guru
Luke, buddy, you're gonna need ladder bars. You can see from the rubber marks that the rear was bouncing some. You started off good, you got at least 20 feet of decent rubber laying, but the last 20 feet you got the spring wrapping going on (rubber for 5 feet and 5 feet of nothing). Next time I'll come and visit you and see if I can put done a longer mark. The rig sounded good, hopefully you can put done some decent #'s in the next met. Thanks for coming out for the afternoon and no beer was drank, go figure that one out. We all where drooling over Tate's new sweet ride.
Old May 5, 2008 | 10:37 PM
  #114
Lil Dog's Avatar
Kenny.... a Valair???
Old May 5, 2008 | 10:39 PM
  #115
Lil Dog's Avatar
I haven't been able to hook up with Vex Tuning just yet to verify all the details for our Dyno event in Red Deer. I am in Jasper here until Thursday. I will update as soon as I can get together with the shop.
Old May 6, 2008 | 06:16 AM
  #116
dodgediesel's Avatar
Sounds great Jason.
Old May 6, 2008 | 12:13 PM
  #117
ramtd02's Avatar
So is the date official yet?? I would like too see what the bigger turbo and second stage of nitrous will give me.....unfortunatly though wedding plans may kibosh my fun
Old May 6, 2008 | 06:23 PM
  #118
Ahhh, weddings happens everyday!!!
Old May 6, 2008 | 08:46 PM
  #119
kennyblatz's Avatar
i realize a southbend is a safe bet but i like to always give the under dog a chance and it seems he knows what he's talking about.
Old May 10, 2008 | 11:14 PM
  #120
MegaMagoo3500's Avatar
Originally Posted by Canuckville
Who's in?!?!?
We got to setup a convoy from Edmonton!
Let's firgure out when and where!! I know its a little early but!!!
Suggestions?!?
That would be sweet. I would love to roll along with you guys. Iam really hoping to get out this summer and meet some of you guys!Ive learned so much reading the posts but just isnt the same as person to person.
