Intercooler Leak
Old Jun 10, 2008 | 10:33 PM
  #31
Lil Dog's Avatar
The PEAK boots are pretty heavy, no need to double clamp with numbers under 50 psi I would think. They are fun to put on boy!
Old Jun 11, 2008 | 08:41 AM
  #32
ccmckee's Avatar
Yeah i'm looking forward to that fight I imagine there will be a few new words invented while i'm doing that.. They even have PEAK printed on them
Old Jun 12, 2008 | 02:50 PM
  #33
Mike Holmen's Avatar
The Guru
I heated mine up prior to installation. What size is the intercooler inlet/outlet?
Old Jun 12, 2008 | 11:31 PM
  #34
ccmckee's Avatar
Got it all done today,the boots weren't that bad to do! A little soap and water and they slid right on. The intercooler i pulled out was a replacement as well, it had a city wide rad badge on the bottom of it.I also had to undo the rad and top hose so i could lift it out of the way to get the intercooler out. From what i can tell so far is the boost actually down to 30psi from 32 but the egt's climb slower and seem to max out around 1450 or so. I didn't have time to pressure test the system yet to see if there are anymore leaks. They are both 4" mike.
Old Jun 13, 2008 | 10:09 AM
  #35
Diesel Dave2's Avatar
Pickin on the wrong admin...
Doesn't 1450 still seem a little high Chris???Could that #8 fuel plate fuel that hard compared to a #10...
Old Jun 13, 2008 | 11:05 AM
  #36
Lil Dog's Avatar
It does seem high for that kind of boost. But its been a while since I had the HX on there. I don't get to that number until around 38-40 psi.
Old Jun 13, 2008 | 03:21 PM
  #37
The Guru
Hah, hah more fixing to come, so I'm not alone. I think you need more fuel and abit more air. You sure that the inlet/outet aren't 3 1/2in. My PDR boots leaked out air and I have to double clamp them. Whats your wastegate set at? I have a brand new HX-40 that needs some soot on her.
Old Jun 13, 2008 | 07:08 PM
  #38
1-5-3-6-2-4's Avatar
I need an HX40
Old Jun 14, 2008 | 07:23 AM
  #39
Tate's Avatar
I thought everything was going back to stock?
Old Jun 14, 2008 | 08:40 PM
  #40
kennyblatz's Avatar
don't wanna steal this thread but does anyone have some pieces made up for doing an air test on the boots/intercooler, they could maybe bring to the dyno day?
Old Jun 14, 2008 | 08:56 PM
  #41
ccmckee's Avatar
I do, if i don't make it i can give it to Dave to bring up.
Old Jun 14, 2008 | 09:35 PM
  #42
The Guru
I got the head on my truck today. Only stripped one bolt, so everything is good so far. I justed used a 4in to 3in exhaust reducer. Put in a 3in valve. Mine works good. I pressure up the system by a 1/2in NPT fitting on the head to an air tool fitting. You can also do the same thing for the exhaust side to see if you have any loose leaky stuff, just pull out the pyro and block the turbine/exhaust flange. If you pressure everything up to check for leaks, you may want to spin loose your rockers bolts, you don't hear air leaking by the valves into the exhaust. All of my neighbors in my area are trying to get me to sell the truck or just trade it off as its too much work to bring my truck back from the dead. I just can't handle the $1200 per month payment each and every month for a new truck that will break just as often as my old beater. Good luck guys getting the rides running.
Old Jun 14, 2008 | 10:55 PM
  #43
tate I need an HX40 for the 12v. not the red truck.
Old Jun 16, 2008 | 12:03 AM
  #44
The Guru
Luke, you gonna put 24v on the rollers? It would be cool to see the numbers prior to unloading the truck.
Old Jun 19, 2008 | 11:19 AM
  #45
I built one also from Chris design...Chris can't make so I will bring mine down..
92smokin blacky
Jan 14, 2010 09:23 AM
6Stix
Feb 13, 2009 08:32 AM
mullishacrew
Oct 30, 2008 09:29 PM
kawi600
Jun 19, 2006 06:44 PM
trik396
Apr 10, 2006 08:18 PM
