intake air
Old Dec 9, 2010 | 12:21 PM
k.si.'s Avatar
intake air
I have been looking at some of the ram air hoods that are available and I have also been looking at installing a pair of compound turbos. So my question is...what volume of intake air is required on a 5.9l? If you look at most class 8 trucks with approx. 15l displacement they do not have much larger intakes than the aftermarket units that we run on our trucks. Is there a formula to calculate the air required? Thank you, k.si.
Old Dec 9, 2010 | 01:55 PM
morkable's Avatar
a ram air hood will probably not give you any extra air at all. They are mostly just for decoration. I dont think that air intake is a problem, once you go to twins a good filter will be sufficient
Old Dec 9, 2010 | 03:03 PM
Tate's Avatar
You need to look at the specs or compressor map for the big turbo. Map's are usually in lbs/min. Multiply that by 15 and you will have the approx CFM that you need. Then you can figure out what filter is adequate.
Old Dec 9, 2010 | 07:38 PM
Mike Holmen's Avatar
The Guru
Getting clean fresh air is always a good idea. I know my compound air filter gets black in hurry. Even if you can boost inlet pressure by a few inH2O (more density), you'll increase inlet volume of the compressor. Garrett/turbonetic's has some good information.
http://www.turbobygarrett.com/turbob...ch_center.html
http://www.turboneticsinc.com/content/compressor-maps
Pratio= (ambient pressure+boost(gauge pressure))/ambient pressure
Old Dec 10, 2010 | 01:02 PM
k.si.'s Avatar
Thank you for the information, I have a lot to learn about the dark art of turbo chargers. I have spent enough time on the computer researching the subject matter that my wife refers to it as "turbo ****".
Old Dec 10, 2010 | 08:38 PM
The Guru
As long as you look and not touch, you could have no issues with the wifey. As much math as you can do, it can only give you a rough idea of what you want. The best way is to try a bunch of different combos, there is nothing wrong with trying to find the perfect set-up for twins. Best place to start for a home build, is to use the stock top turbo and buy a decent primary either a K-31, S475, BTH-3B, GT4202 for the guys running under 700rwhp. Over that you might want something abit bigger. The primary turbine housing size makes a big different on how everything works. If your more inclined, throw in an external gate on the exhaust manifold, you'll probably gain 100-150 rwhp of room with the same set-up. You'll have fast spool-up and lots of top end.
Old Dec 12, 2010 | 07:04 PM
kennyblatz's Avatar
- dont use paper style filters
-try to make sure the air going into your intake has not just passed through the rad or anything else that will have heated it up
- (psi of boost / 14.7) + 1 X CID X max rpm / 20,839 = square inches needed
this is from my turbo book good luck
Old Dec 17, 2010 | 12:51 PM
k.si.'s Avatar
Thank you for all of the information and a Merry Christmas to all.
Old Dec 17, 2010 | 06:08 PM
Blueboy's Avatar
I took out soft plugs in front of #1 and 6 cly,
made plugs 1 1/2" x 4" long to insert in there place.
Went to midas had 1 1/2" tubing bent on 45 and ends
flared for hose. welded short tubes in intake tube, connected
everything with hose and clamps. Have air across intake now.
Taquache
21
Jun 24, 2012 03:11 PM
herb
Jul 18, 2008 08:25 AM
Dodgewincity
13
Jan 19, 2008 05:41 AM
D45
17
Dec 6, 2007 01:52 PM
BA05'CTD
Jan 7, 2007 03:08 PM
