I Think I might have it!
Old Aug 20, 2010 | 04:52 PM
Lil Dog's Avatar
Cool. Hope it works out, been a long journey..
Old Aug 20, 2010 | 05:46 PM
morkable's Avatar
Thanks buddy! Me too,,, it has been a very frustrating year that is for sure
Old Aug 21, 2010 | 10:25 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Don't forget the beers Kevin......Just giving you a hard time buddy......I know its been really frustating for you..
Old Aug 21, 2010 | 08:55 PM
Mike Holmen's Avatar
The Guru
Hate to ask Kev, so did the monster start buddy?
Old Aug 21, 2010 | 09:12 PM
morkable's Avatar
Be tomorrow Mike. Went quadding today. I will work on it tomorrow
Old Aug 22, 2010 | 04:05 PM
morkable's Avatar
Well I dont got it,,,,,,,,, I am getting so frustrated. Going to pull the head tonight. Starting to think that I got ripped off now.
Old Aug 22, 2010 | 04:28 PM
1-5-3-6-2-4's Avatar
did you compression test it and leak down test it?
should do that before you actually pull the head. I mean for the time it takes. you should know what or where to start looking.
Old Aug 22, 2010 | 04:55 PM
Darn...was hoping it was the lines...that was cause all the problems..
Old Aug 22, 2010 | 04:59 PM
morkable's Avatar
Luke I dont have a compression tester unfortunately
Old Aug 22, 2010 | 06:04 PM
I would try to get my hands on one before pulling the head. and do some diag before disturbing the seal. compression test each hole. then back off all the valves. or even pull all the rockers. and pressure up each hole do a leak down. then toss some oil in the hole on the rings and walls. re do the leakdown. to find bad valves or cracked head or headgasket even.
do that before pulling the head.
Old Aug 23, 2010 | 06:54 AM
Tate's Avatar
x2!
If you get in there and find nothing out of the ordinary, you've pulled the head for nothing and still no further ahead.
Old Aug 23, 2010 | 08:23 AM
morkable's Avatar
I found a buddy that has a compression tester and a leakdown tester. Just have to make them work together. Be about a week or so before we can do it though.. I have pretty much ruled everything else out though... I sure am getting frustrated I can tell you that
Old Aug 23, 2010 | 07:54 PM
compression test and leakdown use the same injector adapter. just the air is going in opposite directions.
laekdown puts shop compressed air into the cylinder. and you listen for where it comes out. IE - blowby into crankcase listen to breather. pull intake horn listen for air. pull rad cap try and make that highest point - at radiator. check for bubbles in coolant reservoir. then oil the cylinder walls turn the engine over by hand to get even coat. that ensures a positive ring seal... if the rings are good. then that isolates air on the topend. make sure you have a shutoff valve for the air. it should hold pressure with the rings oiled. if not you have a majjor problem.
and the compression tester should have a 1 way check in the guage. or its impossible to read. and shooting for 350psi or better. and even pressures across them all. for a healthy card. compression test is easier. should do that 1st, then you have a preliminary on what you got, then you can focus attention in the leakdowns.
Old Aug 24, 2010 | 09:27 PM
Keep us updated Kevin....
Old Aug 24, 2010 | 10:20 PM
winkdemon's Avatar
hey kevin
if there is anything i can hope with let me know , i have alot of parts kicking around
