Hx 40 Question
Hx 40 Question
just wondering if you can get a 12cm and or 14cm hot housing for them ?
i would like to but a fancy turbo for the truck but i have the hx 40 so i will use it now ,,,, but i would like to put a tighter housing on it
I have a couple 12cm's on HX-35's you could try, I would be willing to trade if it works.
It does on the compressor side with the backing plate, but not a 100% sure on the hot side. My turbos are just sitting collecting dust right now, I can pop off one of the hot sides, and we can see.
I'm pretty sure that the 35 tubine housing will not fit onto the 40 bearing housing. I haven't worked on one of these turbo in awhile, but if my memory is correct the 40 bearing housing is bigger than 35. A hot deal wink is to score a slightly used, but electronics toasted 6.7L turbo. They work nice and have the ablity to use the exhaust brake. There a fella on the comp diesel that has that set-up. I bet you can buy a 6.7L turbo for less than rebuilding that 40. Really that 40 needs an enlarged wastegate on 14cm. Thats what PDR did. They also used an large o-ring on compressor housing for sealing, holset housing leak that valuable boost.
Two advantages of using the VE351 or 6.7L turbo, variable vane turbine. The compressor impeller is nearly the same size. The turbine disk should be smaller as well. That should fix the laggy 40 issue, but doing that you creating more drive pressure and will limit top end power.
well i was thinking f putting the hx-40 0n my 1995 as a single and using something else for the twins , my hx-35 is starting to use oil so it's on it's way out ,,,, and i would like to cool the egts off for when i pt stivks in my 1995 ,,,,
