How much do you think that one 5.9L cummins pistons/rod weighs?
I was going to get the wrist pins gun drilled. Once we get the rods off, we can put together a plan. I found a shop to do the oil cooling jets modification that I have in mind. I guess that its pretty common stuff for the older motors to break off a jet
, things you make you go hmm...
will taking rotating weight off actually reduce torque or will it just push the high end horses up? And from what i remember of my rods they have just a flat bottom on the caps as rage there said.
and as for your 8 and some pound rod discovery, thats why i don't ever want to go over the factory rev limit.
Are you gunna be milling wieght off your pistons? I'd like to see how drilled out rods would hold up as well. You know you want to mike.
Anybody give a thought to how the small end of the rod (wrist pin) gets its oil lubrication from? The only way that the oil gets up there is from the oil cooler jet. The jet coats the cylinder wall as well as the piston bottom.
The CR rod has a smoother finish to it. These older rods are have more beef to them and are truely forged pieces.
Of course the crank will have to balanced for the weight changes.
I plan to cut a few pistons up first to see how thick everything is. Might only have the fly cuts this year, I'm running stock pistons for now.
Before I forget
, what colour you guys think we should paint the motor? Right now I'm think ford blue or the cummins red. Thoughts guys?
Might limit the speed of the truck if you paint it blue, but we have to please the ford purists abit on this build.
Piston crown thickness is thick for a reason and so you have to be carefull on what to remove and what not to remove, after all this is a diesel engine and the combustion occurs inside the piston bowl and I plan on using NOS
About twice what Kev does and about half what Ellerton uses.
Its already that color. I rather have a shiny CTD motor/twins set-up. I hoping the winter we can paint the truck, when we are bored and out of projects and nearly out of beer
No the Block is all one color right now, to match the truck with the doors and bed sides and front end, it would have to be lots of colors...
I suppose we should paint the mounts then too, but they should be black so people don't notice them.
I want to chrome those baby, that's nice fab work buddy. The workmanship thats putting this truck together is pretty decent. I want everyone else to see that as well. Watching those videos on comp D a newly built ranger today made my day. Now I really want to get this ride built.
Silver Ram
32
Dec 28, 2010 08:34 AM
RollinCoalSmoke
May 29, 2009 09:20 PM
ddestruel
May 10, 2005 12:17 AM
