Generator question
Old Aug 29, 2011 | 08:48 AM
morkable's Avatar
Generator question
Hey guys got a question. I have a 7500 onan gen on my motorhome. It is powered by a 3 cyl cummins with a small p pump on it. Anyways what is happening is that it will run for a little bit and then quit. I started doing it qt blackout. When I got home I did a complete service in it (oil, filter, air filter, and fuel filter) seemed to work good at home but now I'm on the road again and it won't stay running again. Any ideas?
Old Aug 29, 2011 | 09:06 AM
ccmckee's Avatar
Air getting into the fuel line maybe ?
Old Aug 29, 2011 | 09:08 AM
dvst8r's Avatar
Mechanical or electric lift pump, or any at all?
Fuel shut off solenoid?
Old Aug 29, 2011 | 01:00 PM
Lil Dog's Avatar
Sounds like fuel supply. Unless the controls are getting a wayward ESD signal.
Old Aug 29, 2011 | 11:13 PM
morkable's Avatar
No lift pump at all.. after I changed the fuel filter it seemed to work just awesome. Until I started driving,, then it just wont stay running. I dont think it has any electronics at all (if that helps) I definately think it is a fuel issue though for sure.
Old Aug 29, 2011 | 11:26 PM
tech-eh's Avatar
the fuel tank has crud in it as you drive it shakes up crud is ingested by filter as it is suspended in fuel .when you were at home and changed it all had the motor home had been sitting a few days ?
so wait till its parked twenty min or so change the filter and see what happens . or go and run it off a Jerry can to test it . you might have to prime it though
Old Aug 30, 2011 | 01:09 AM
morkable's Avatar
That makes sense,,, it seems to happen when the fuel tank gets to below 1/2 tank,,, the MH itself wont run if it gets down to 1/4 tank,,,,, crap that sucks
Old Aug 30, 2011 | 07:10 AM
dvst8r's Avatar
Hellman sump for the genset...
Old Aug 30, 2011 | 07:38 PM
morkable's Avatar
I think that there will be a brown mh on the lot in red deer next week. Frickin thing. Started it up this morning worked like a champ
Old Aug 30, 2011 | 10:13 PM
tech-eh's Avatar
parked all night not moving eh .there may be a drain valve and it could just be the accumulation of water and other crud over the years . drain it replace it see what happens but drive it for ten min or so over bumpy rds first. I have kid you not found a Bic pen cap in a fuel line came off as some one was writing a report on fuel level ,took three months before that one was figured out as it would be fine most of the time as the cap floated !!!!
Old Sep 3, 2011 | 01:52 PM
Robert373's Avatar
My Second Year HD instructor told us about an experience he had with a Class 8 tractor. Same kind of idea, would stall when moving randomly for no reason.
He finally found a small piece of clear plastic wrap in the fuel tank, which would every once in a while block the pickup as it sloshed around the tank. It could not be seen floating in the fuel.
BigBlue
Apr 2, 2006 09:22 PM
George&cheryl
Mar 8, 2005 12:03 PM
firepiper
Jul 5, 2004 03:57 PM
tool
Feb 7, 2004 12:25 AM
Jack Thorpe
Aug 7, 2003 12:36 PM
