fitting sizes
Old Nov 2, 2009 | 06:07 PM
Mike Holmen's Avatar
The Guru
What tubing size you gonna use. 1/2in stuff is pretty easy to work with. Once your done, your done. Its worth the money. Greggs, would have the metric AN or JIC stuff, if you want to save a couple bucks. Stainless is the way to go, if you hate leaks. I just hate rubber, at some point it will fail. Bending the tubing, is fun stuff, its almost as fun as building intercooler air tubing. I like that kinda of stuff, some don't but I like stuff to fit purfect
Old Nov 2, 2009 | 06:16 PM
morkable's Avatar
Yeah, I want it to look perfect! (well as close as I ever get to perfect,, LOL)
Old Nov 2, 2009 | 06:38 PM
The Guru
Kev, I hate to ask this, but did you get your truck into the diesel mag? My memory is abit fussy..
Old Nov 2, 2009 | 09:30 PM
morkable's Avatar
not yet,, dont worry i will be shouting it from the roof tops when it does
Old Nov 2, 2009 | 09:31 PM
morkable's Avatar
Hey I have just thought of another stupid question... as far as return lines,, there would be just the one off of the back of the head, and 1 each from the cp3's right? There shouldnt be any others that I am missing in my head right now?
Old Nov 2, 2009 | 11:35 PM
rage_blue's Avatar
Just don't forget to make sure that any stainless braided hoses that have rubber inside them have to be diesel compatable. Non diesel compatable hose lasts hours with diesel feul.
Old Nov 3, 2009 | 12:28 AM
morkable's Avatar
The teflon ones should work shouldnt they?
Old Nov 3, 2009 | 12:42 AM
Dr. Evil's Avatar
yup.
The Sawgelok ones youd be looking at should all be teflon inside.
Old Nov 3, 2009 | 12:47 AM
morkable's Avatar
I am not sure that I will go with swagelock for the fuel system.. maybe on the tranny,,,, any ideas as to what I am going to need for fittings on the tranny?
Old Nov 3, 2009 | 09:53 AM
Dr. Evil's Avatar
Not really - shouldnt be hard though. I dont have an re48 to look at. Im sure someone here will be able to help with that.
This is the stuff you will want to use:
http://www.swagelok.com/search/produ...art=SS-8BHT-12
Are you wanting metric or SAE?
Old Nov 3, 2009 | 06:23 PM
The Guru
I would pull out the fittings and take it to the swedgelock dealer. Remember to take the fittings out of the tranny heat exchanger and off the tranny cooler. Its NPT but I can't say exactly. The tranny might be 3/8in and the cooler is 1/2 or 3/4. You could use a swedgelock flare fitting outside the casing. I usually just raid the fitting cabinet at work. You gonna use 1/2in stainless tubing? Remember to flush or blow out the lines and makes sure everything is clean as it goes together. I hate to have to ruin a tranny or a motor just because of dirt. Especially on that 9's run, that you been dreaming about. Hows the monster build going buddy?
Old Nov 3, 2009 | 07:01 PM
morkable's Avatar
Its going slow,,, but should pickup speed here soon... doing the cage next weekend,, pumped about that,, engine should be here next week, uber pumped about that..
What do you think about using SS braided lines for the tranny?
Old Nov 3, 2009 | 07:08 PM
The Guru
You could use hydraulic lines if you want. Its easier, than stainless. I just like stainless tubing, its a fetish? I do enough at work and 1/2in bends easy. I plan to drive my truck for another dozen years, so I can't have a line break during driving. I'm gonna pass 70k this year. I have to go back to Chicago next week. Might break the 10k in month.
Old Nov 3, 2009 | 07:12 PM
morkable's Avatar
LOL,, I am almost 60 on my truck (chevy) for the year, with 2 more trips to gp and back slated yet... I think that there is going to be a new dodge on the horizon
Any advantage to going with the stainless? The disadvantage I see is being able to move things,, like the cooler,.
Old Nov 3, 2009 | 07:20 PM
The Guru
None really, stainless is more long life, more resistant to failure as its rated for 2000+psi. Most hydralic hose is as good as tubing. Automotive hose, its junk. Its just an accident waiting to occur.
At least your still in Canada. I just enjoy the crossing over point into USA. Every crossing its a heavy drama. Last time I was in the holding cell for 2-3hrs. The time before they have a drug dog go thru my truck and the dog peed on my tires.The time before they thought that my truck was radioactive.
