Clutch install
Old Jul 30, 2008 | 05:56 PM
kennyblatz's Avatar
The only thing I see is missing is the beer. Makes this go abit more smoother not biter. My tranny jack is just an car jack adapter as every tranny jack didn't drop down enough for me to pull the transmission out from under the truck. You guys shouldn't have that problem. You just have to pull the tranny back enough to get at the clutch. If you have a big inch exhaust you might curse some as the top tranny bolts are a bugger. Tate, did you leave the transfer case attached to the tranny or you remove it on Kenny truck? You probably could get away with leaving it attached, but you'll have to get the chains on tight around the transmission. The DTR pit crew in action. Too bad I'm going camping sounds like a fun fun afternoon.
t-case was left on, big thanks to tate he saved me a lot of money. clutch is making a little noise again not the same though im just hoping for the best. if this thing lets go i might have to look into a auto swap shifting takes way to long.
Old Jul 30, 2008 | 11:26 PM
Tate's Avatar
Originally Posted by Lil Dog
Hardcore Tate... You are now officially part of the Two Clowns group by now aren't you?
I don't know, its been a long time since I've talked to any of the clowns.
Kenny, is it the same kind of noise as before? This is where a real small boroscope would be handy, to take a peak in there without yanking the whole works. Hope its not another failure, I only have 2 more input shafts left.
Old Jul 31, 2008 | 12:07 AM
ccmckee's Avatar
Is there a pilot bearing on these trucks? And yes us clowns have been quiet lately
Old Jul 31, 2008 | 12:20 AM
Tate's Avatar
Yep, pilot bearings come pre installed in the flywheels. Upgraded roller or ball bearing setups, not the wimpy needle bearings.
Gonna come out on the weekend to drop some tools on Dave's head?
Old Jul 31, 2008 | 12:34 AM
Lil Dog's Avatar
I happen to have a rigid borescope.. 10mm diameter by about 30" long. Would you just go through the side boot?
Old Jul 31, 2008 | 02:44 AM
Tate's Avatar
Did you get that from Home Depot for around $200 or so? I was gonna pick one up, but the one in Airdrie 'lost' the one they had.
I'd likely suggest pulling the slave cylinder off and going into the bell housing that way. The tube on the input shaft bearing retainer, that the throw out bearing rides on, snapped off on Kenny's tranny. Not sure what would cause that, but if it happened once, it might happen again. Can't see it being an alignment issue, as that should be binding the pilot bearing.
Old Jul 31, 2008 | 06:38 AM
kennyblatz's Avatar
no befor it was a squeal when the clutch was pushed in now i get a little noise when the clutch is engaged from a stop. so it might just be a random friction noise i guess. it hasen't gotten worse so i'll play it out worse cause senario i get a triple disc clutch right?
Old Jul 31, 2008 | 10:10 AM
Lil Dog's Avatar
No, not Home Depot .. Everest VIT, now GE Inspection..Everest Scope.
Interesting noise problem..
Old Jul 31, 2008 | 10:49 AM
1-5-3-6-2-4's Avatar
bumm-air kenny. hope its not bad. I helped a bud R&R his auto last week. I tell you WHAT autos are way easier than 4500s. That crossmember...ya. used a big bar to wedge up under it and it walked out pretty easy. before reinstalling it....get your BFH and give it some love on the tapered sides helps it go back in way better. far less hammering. and the bolts suck it right back into shape. I'd come help you guys but I'm on shift all weekend. But after the 11th I'll be back on a regular M-F days shift......going to work at Waterous.
Old Jul 31, 2008 | 11:14 AM
ccmckee's Avatar
I'd come too but i'm still on holidays and we are heading to Edmonton for the weekend.
Old Jul 31, 2008 | 06:33 PM
ccmckee's Avatar
Tate, i told Dave too stop and pick up my old intercooler on the way by this weekend.I am leaving it beside the house, if you are talking to him in the mean time you bette remind him about it. He's getting that CRS like the rest of us
Anyone want a good 12V head before i send to the scrap yard ? Been sittin on my garage floor for 2 years now in the crate the new one came in, getting tired of tripping over it.
Old Jul 31, 2008 | 08:23 PM
Tate's Avatar
Ahh, I misunderstood. Rigid (the company) has a boroscope at home depot, but its flexible.
Chris, maybe I could take you up on that head too? What a mooch I am. Want cash or beer in return? I have a feeling my 2500 will need an o-ringed head sooner or later.
Old Jul 31, 2008 | 10:32 PM
Oh bugger you beat me to it..........I'd scoop that 12v lid too.
Old Aug 1, 2008 | 08:38 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Darn....Tate is the winner...Chris told me several times to pick that head up...Oh well first come first serve...
Old Aug 1, 2008 | 09:38 AM
ccmckee's Avatar
I may need a timing job again Tate once my new turbo gets here.
