Blew apart both of my Bilstien 5100's.
Old Nov 2, 2009 | 11:22 PM
rage_blue's Avatar
blistens are a gas charge shock aren't they? A little more high end than i'm used to. Are they worth it for ride? I think a second gen could use any help it can get for a better ride.
Old Nov 2, 2009 | 11:24 PM
nickg's Avatar
I like the ride from my Bilsteins 5100's, but now thanks to Swamp I worry.
Mike
When I ordered my 3rd gen trackbar from SSI I talked to Russel, and he told be that he had his shocks freeze up as well, froze so bad they would not move, moved his truck back into a heated garage and they thawed out, he said they apparently dont have a oil with low enough viscocity for our low temps. I thought he told me they froze at -35-40C. made me nervous as well, I have bilsteins as well, shocks are holding up fine so far... I believe I've read that they dont warranty any shocks that are longer than stock (just hearsay)
Old Nov 3, 2009 | 07:51 AM
Mike Holmen's Avatar
The Guru
My next set, I want to upgrade up to the next level. I do lots of off highway driving and the shocks seem to help keep the four wheel planted decently. That cali 2.6 suspension kits is the cat meow. Swamp, you'll have one cool work truck. The 2.6 kit is suppose to have a better ride than factory, almost 1/2ton like.
Old Nov 3, 2009 | 07:59 AM
Danderson's Avatar
Originally Posted by Swamp_Donkey
I am not opposed to trying newer better parts..... Will look into these 2.65.
Carli substitues a thinner oil for you cold weather guys. Contact him.
Old Nov 3, 2009 | 09:06 AM
roxxx's Avatar
Originally Posted by nickg
Mike
Had mine warranted already for leaking oil
Mine are not what came on the grampa truck
just an FYI its lookin like the bilstiens are on back order to to make things worst, I know I waited 6 weeks for my replacements
Old Nov 3, 2009 | 04:25 PM
D-Roc's Avatar
Looks like your diff cover was off in one of those pictures...were you changing your oil out in a snow drift?
Old Nov 3, 2009 | 08:55 PM
01 Diesel Nut's Avatar
I put their coils in the front of my truck not to long ago, and those alone helped improved the ride vastly, those with a higher end shock like the 2.65s would make it ride very noice, I know when I have some extra cash after I make 'er go fast I'll be throwin some more carli bling into the front of my rig..
Old Nov 3, 2009 | 10:18 PM
krh's Avatar
krh
well at least you blew em up good. Makes troubleshooting that rough ride that much easier.
Old Nov 3, 2009 | 11:22 PM
Mocho's Avatar
Looks fun! Atleast I got something to look forward to, 1 of my bilsteins is already making a god awful noise on bumps, don't think I got 10,000km on them yet.....I wouldn't buy bilstein shocks again, ever
Old Nov 5, 2009 | 09:57 PM
nickg's Avatar
Right now I'm driving around with one KYB and one bilstien on the front, reason is somehow I ended up with the wrong Carli springs, so when I hit a pot hole at higher speeds the front end will start hopping like I got a square tire on the drv side, so I stuck the KYB on there and now potholes are more manageable, the kyb has over 100,000kms of intown courior use on them, and to be honest I dont really see that much difference between the 2 brands except for the price (KYB was around 90$ ).
I'm wating for HRT to get in a set of "hemi" springs from Carli so I can swap them out. apparently some trucks (second gens) dont respond as well to certain spring rates as well as the 3rd gens do.
Moral of the story is I think the KYB(mono max) is a good shock, and for what its worth I got a set of procomps on the rear that were only 60$ each and they have help up fine except for having to replace one set of rubber bushings on one side.
Diesel nut:
I agree the carli springs is a huge improvement in ride (except for the square wheel thing happening) so did they instal "hemi" springs???
Old Nov 5, 2009 | 10:14 PM
Mocho's Avatar
Diesel nut:
Yea I know a lot people praised Bilsteins, I don't know if I drop the extra coin on them again. Glad my noise was just a loose bolt, not sure how but o well. Been so long since my truck had no noises, it seems almost to quiet
Old Nov 5, 2009 | 10:42 PM
I believe that I got the hemi springs in the front of mine.
Old Nov 5, 2009 | 11:14 PM
Swamp_Donkey's Avatar
Nickg,
I originally bought my Carli starter kit from Kevin @ HRT. After 3 phone calls on Monday and tuesday without him returning my calls because I also had other issues with my Carli anti sway bar end links I took my business elsewhere. Never did get to talk to him. I called interior off road out of Edmonton around noon yesterday and picked up my shocks 18 hrs later @ FSJ greyhound this morning. HRT seemed to be OK to deal with the 1st time......
Old Nov 5, 2009 | 11:42 PM
k.si.'s Avatar
I had the same problem with HRT, not returning phone calls or e-mails. So I have started to deal with Chris from Big Dog in Calgary. Thank-you, ksi.
Old Nov 6, 2009 | 12:40 AM
Mocho's Avatar
Nickg,
Never dealt with HRT, but I will say interior has been good to me the few times i've been there, even for parts that aren't worth much. The only thing is their hours SUCK.
