anyone got a old head kickin around
Old Jul 30, 2009 | 03:31 AM
kennyblatz's Avatar
i want to make a intake manifold for my truck so i was wondering if anyone has a damaged or old head kickin around i could borrow. maybe a few cold ones for rental fees
while im at it anyone know where i can get hanging weights for a good price, i wouldn't mind loading down my truck for the pulls at AAB
thanks
Old Jul 30, 2009 | 08:17 AM
dodgediesel's Avatar
Tate or Mike Holmen will hook you up!!!!
Old Jul 30, 2009 | 10:36 AM
Mike Holmen's Avatar
The Guru
To bad your in Edmonton. I have one available
Old Jul 30, 2009 | 10:15 PM
Tate's Avatar
Call Aaron at CT in Rimbey. I never picked up that 24v head I got from Jamie when I found out it was cracked. He might still have it kicking around. If he does, I should hope that its a freebie.
Old Jul 31, 2009 | 01:17 AM
kennyblatz's Avatar
ok thanks mike is that a good head or damaged?
i'll call ct thanks tate
Old Jul 31, 2009 | 07:54 AM
The Guru
damaged and the intake plenum is been torched somewhat
What are you planning on doing with the head? I have to go up north in a few weeks, I can drop it off for ya.
Its a scrap head and can't be used on a running engine. I do have another one, but I want to keep it. The valve seats are cracked. I have a dream that I can repair it, someday.
Old Jul 31, 2009 | 02:02 PM
kennyblatz's Avatar
Aaron is going to bring me tates head that he has there. I'm going to make some intake manifolds (or so I hope) the tricky part is custom injection lines
Old Jul 31, 2009 | 09:24 PM
1-5-3-6-2-4's Avatar
bending SS tubing isn't that hard once you get the hang of it. you know all 6 lines have to be exactly exactly the same length though right. or your injection timing will be toast.
Old Jul 31, 2009 | 11:16 PM
kennyblatz's Avatar
yeah im not sure if im going to do it or have someone else bend them up well see, pretty expensive to be making mistakes on.
Old Jul 31, 2009 | 11:20 PM
Tate's Avatar
Get the straight lines that are equal length, bending won't be that hard if you don't have to have them factory looking. Look at any high hp puller, the lines look like ****, but they do the job, and thats what matters.
Old Jul 31, 2009 | 11:29 PM
morkable's Avatar
I would think that you could use one of those little tube benders that plumbers use,, should work shouldnt it?
Old Aug 1, 2009 | 12:53 AM
thats zactly it, a tubing bender is a tubing bender. you just get them in different size ranges.
Old Aug 1, 2009 | 03:17 AM
kennyblatz's Avatar
Well I am a pipefitter by trade so I'm sapposed to be pretty good at it but haven't really had to do it yet. I have access to the benders so I might just get a lenght of tube and mach it up befor bending each one like tate says my old farm truck ain't for looks.
Old Aug 3, 2009 | 04:41 PM
The Guru
If you're going that far as too bend your own lines, I would put a P7100 pump in your truck. What are you thinking about doing for intake mods?
Dodgezilla
Nov 6, 2011 04:13 AM
kennyblatz
ABDTR #5
May 22, 2011 06:54 PM
chariotdriver
Oct 18, 2008 10:50 PM
2006 MEGACAB
15
Aug 16, 2007 11:56 PM
