Seatbelt alarm in my 2011
Was curious if there is a way to shut off the seat belt alarm in my 11 3500. I use the truck around the farm getting in and out all day and the lil alarm reminding me to buckle up is gettting annoying. On my 04 Ford the manual said to click and un click the seatbelt some many times with the key on and it shut off. Was hoping Dodge offered something like this. Thanks..
From the owners manual...
BeltAlert can be enabled or disabled by your authorized
dealer or by performing the following procedure:
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the
ON/RUN or START position. Chrysler Group LLC does
not recommend deactivating the BeltAlert.
1. With all doors closed and the ignition switch in any
position except ON/RUN or START, buckle the driver’s
seat belt.
2. Turn the ignition switch to the ON/RUN position and
wait for the Seat Belt Reminder Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle
and then re-buckle the driver’s seat belt at least three
times within 60 seconds, ending with the seat belt
buckled.
NOTE: Watch for the Seat Belt Reminder Light to turn
on while the seat belt retracts and turn off while rebuckling
the seat belt.
4. Turn the ignition switch to the LOCK position. A
single chime will sound to signify that you have successfully
completed the programming.
BeltAlert can be reactivated by repeating this procedure.
NOTE: Although BeltAlert has been deactivated, the
Seat Belt Reminder Light will continue to illuminate
while the driver’s seat belt remains unbuckled or
unretracted.
seat belt.
buckled.
the seat belt.
unretracted.
Hey that was great, worked on mine just got done doing it, the only thing you forgot was the step where you put your left foot in you take your left foot out and shake it all about
but for real it did work and thanks for looking up or figuring that out.
Bradjun1
Mar 10, 2011 06:41 PM
Hummin Cummins
15
Mar 6, 2003 06:45 AM
