Seatbelt alarm in my 2011
Was curious if there is a way to shut off the seat belt alarm in my 11 3500. I use the truck around the farm getting in and out all day and the lil alarm reminding me to buckle up is gettting annoying. On my 04 Ford the manual said to click and un click the seatbelt some many times with the key on and it shut off. Was hoping Dodge offered something like this. Thanks..
From the owners manual...
BeltAlert can be enabled or disabled by your authorized dealer or by performing the following procedure: NOTE: The following steps must occur within the first 60 seconds of the ignition switch being turned to the ON/RUN or START position. Chrysler Group LLC does not recommend deactivating the BeltAlert. 1. With all doors closed and the ignition switch in any position except ON/RUN or START, buckle the driver’s seat belt. 2. Turn the ignition switch to the ON/RUN position and wait for the Seat Belt Reminder Light to turn off. 3. Within 60 seconds of starting the vehicle, unbuckle and then re-buckle the driver’s seat belt at least three times within 60 seconds, ending with the seat belt buckled. NOTE: Watch for the Seat Belt Reminder Light to turn on while the seat belt retracts and turn off while rebuckling the seat belt. 4. Turn the ignition switch to the LOCK position. A single chime will sound to signify that you have successfully completed the programming. BeltAlert can be reactivated by repeating this procedure. NOTE: Although BeltAlert has been deactivated, the Seat Belt Reminder Light will continue to illuminate while the driver’s seat belt remains unbuckled or unretracted. |
Thanks for that post. Will perform that tomorrow.
Hey that was great, worked on mine just got done doing it, the only thing you forgot was the step where you put your left foot in you take your left foot out and shake it all about[laugh] but for real it did work and thanks for looking up or figuring that out.
