Cabin Filter Mod
Old May 12, 2011 | 10:23 PM
Albertaguy's Avatar
This is going to be a very dumb question. I went to my Dodge dealer and bought the filter box lid but did not get the filter as I wanted to get the Wix charcoal one but only took that number to my local Canadian Tire to find out they do not stock them so will pick one up at another source. I have not removed my lower glove box until I get all the parts in place. My dumb question is this, does the filter fit into the filter box and then slid into the opening? And then the metal cover replaced? I know this is dumb but as I have not removed the glove box,I am a little confused with the pictures.
Old May 12, 2011 | 11:59 PM
sledhead01's Avatar
Wink
It will all make sense when you remove the lower glove box. You need to cut out the opening for the filter. Just follow the instructions on the first page. Then simply insert the filter into the opening and snap the lid on to hold the filter in place and close up the air box.
Good luck
Old May 13, 2011 | 08:09 AM
Albertaguy's Avatar
Good luck
I get the picture now, thanks!!!!!
Old May 13, 2011 | 03:30 PM
New2Diesel's Avatar
"Gomer Pyle"
Has anyone noticed less air flow with the mod? Mine seems to blow hardly no air
Old May 13, 2011 | 05:13 PM
cbrahs's Avatar
no reduced flow here. make sure the filter is in correctly.
Old May 16, 2011 | 11:45 PM
sledhead01's Avatar
No reduced flow. Mine still blows like a cheap........
Old May 17, 2011 | 05:26 PM
New2Diesel's Avatar
"Gomer Pyle"
Mine blows like a "Cheap" also! Ha,Ha. Seriously, thats why I asked the question.
Old May 20, 2011 | 02:45 PM
unit74's Avatar
Went to the local dealer to get the cover. It was $19.98 with tax. Bought the WIX carbon filter on Amazon. Cheapest place I could find it.
Old May 20, 2011 | 02:55 PM
redlineguy's Avatar
Did mine last weekend, The cover does not seem to "snap" on it just kind of stays there??
Old May 21, 2011 | 10:48 PM
Albertaguy's Avatar
I completed mine this afternoon, just before the world was going to come to an end. I found it difficult to cut out the plastic piece using a utility knife, so I was able to start the hole then used a hacksaw blade to finish it and then a dremel tool to clean it up. I bought the cover at my local Dodge dealer for 14.95 and the Wix carbon filter for just under 15 bucks. My cover did not click in place but it seem to be tight and not easily removed, so I figure I am good to go.
Old May 22, 2011 | 12:53 AM
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
Excellent!
For those of us with algeries to pollin. . . Nuff said
Moved to the top fo the truck to do list
Old May 22, 2011 | 09:25 PM
unit74's Avatar
No, mine snapped on. There are tabs on the left and right sides of the cover that snap onto nubs on the side of the air filter box.
What I also found is that you have to cut the opening flush with the outline to get the filter in. I left a little "extra" and had to re-cut, which turned in to a mess of little chips falling into the blower. Just cut it flush with the outline the first time.
Old May 26, 2011 | 06:01 AM
redlineguy's Avatar
No snap on mine
Old Jun 5, 2011 | 11:06 AM
unit74's Avatar
No snap on mine
FWIW....
Mine is a late production 2011 3500 HD. I just got the truck. Maybe they changed up the blower box?
Old Jun 7, 2011 | 09:36 AM
redlineguy's Avatar
FWIW....
Not likely do to the cost. I need to look at mine agin maybe something is sticking out.
