Backup Camera Relocation
Old May 19, 2017 | 09:31 AM
Gordsram's Avatar
We are waiting for delivery of our new 3500 longbox Laramie ( in white ). It is replacing our 2004 dually. We will be using a " spacekap" slide in canopy which requires removal of the tailgate.
Does anyone know if I can remove the backup camera from the tailgate of this new truck and relocate it to my canopy? I will have a lot of flexibility as to relocation location.
Thanks in advance for any responses.
Gord
Old May 27, 2017 | 09:57 PM
gsbrockman's Avatar
I can't guarantee these part numbers will work on your 2017---but it might get you in the ballpark :
56038978AG camera rear view
68189124AB wiring tailgate
68224929AA wiring jumper
The above numbers allow you to keep your OEM stuff in your tailgate. That way---it's unmolested when you get ready to re-install it. The above numbers should also be plug-and-play. No cutting, splicing, or soldering.
If the tailgate wiring is not long enough for your proposed mounting site, you might have to go with a harness from a Cab & Chassis application. It will most likely require cutting & splicing & soldering though.
Old May 29, 2017 | 02:46 PM
1-2-3's Avatar
Just a plain ole guy
When I added my camera (aftermarket) there was a spot in the tailgate handle for it. I would think you can just take off the cover and reach in and pop that camera out of the handle and get a drill bit that size and make your own bracket for it to fit anywhere. Certainly worth opening the tailgate cover for a quick look.
RetiredCGRider
Nov 14, 2010 11:36 AM
checkster
May 26, 2009 08:20 AM
VictorC
Mar 17, 2009 06:19 AM
Backwoods
Oct 18, 2008 05:49 AM
hotdram
Aug 17, 2008 10:14 PM
