5th wheel hitches???
Old Jun 16, 2011 | 10:45 AM
firestorm's Avatar
Originally Posted by Busboy
I was disappointed in their removal and installation practices but after asking a few questions on this site I discovered an alternate method and it's been great. Extremely pleased with it and the quality is exceptional, worth every penny.
I assume your talking about how tight the locking pin is, that holds the hitch in the receiver, correct? I need to re-adjust mine, I can't get it to unlock.
Old Jun 16, 2011 | 03:25 PM
Busboy's Avatar
That's correct, I shimmed mine then tightened it to their torques. By shimming it stops the post from tightening up on the locking pin yet it's in the right location every time. Just means I can take the hitch in and out without unbolting every time. There are a number of people doing it this way and what made me even more comfortable was one person said they did a bunch of miles without the pin in as they forgot to lock it so really what kind of load is actually on that pin. I'd say zero.
Old Jun 16, 2011 | 07:05 PM
firestorm's Avatar
Thank you.
Old Jun 16, 2011 | 07:16 PM
Blake Clark's Avatar
Ive never had an issue with my Companion. Set it the first time and it comes out really easy.
Just lucky I guess
Old Jun 16, 2011 | 09:05 PM
Busboy's Avatar
Just lucky I guess
Their instruction now say to torque the pull down bolt to 40 ft lbs against the lock pin then tighten the u bolts to 80 ft lbs. They say you should NOT be able to pull the pin release.
Old Jun 23, 2011 | 10:54 AM
Grand Geek's Avatar
wow that seems excessive to me.. i set mine up with the companion sitting in the hole and did up the pull down bolt so it was just pulling on the pin. My wife can pull the pin handle easy..
keep in mind the Companion is rated for 16000 lbs..
Old Jun 23, 2011 | 11:18 AM
firestorm's Avatar
Mine says it's rated for 18k, but I have no intentions on testing it. I've just about got mine, shimmed out.
Old Jun 23, 2011 | 11:39 AM
Grand Geek's Avatar
Firestorm.. you are correct.. With that in mind i was 2018 lbs away from max load not 18 lbs away from max load..
Old Jun 23, 2011 | 04:28 PM
Can ya point a fella to the shimming technique???
Mine works fine as is, just curious.
Old Jun 23, 2011 | 06:15 PM
Virginia Diesel's Avatar
I had a slider in short bed Dodge 1500 and ALWAYS used the slider when backing up and parking the trailer. The distance was to close and even busted my back glass one time (bicycle) and trailer to close when not slided back. Better safe than replacing a window. I have LB now and don't need it, but installed it anyway so I didn't have to buy a new hitch.
Old Jun 23, 2011 | 06:50 PM
Busboy's Avatar
There is no "approved" method only the factory method but that fails to account for the hitch being removed and installed constantly. The pull down bolt and the u bolts will stretch over many applications and the lock nuts (which really should only be used once) will lose their locking ability. What I did was install large washers on top of the post I added different thicknesses of washers until the lock pin could just be removed with the bolt torqued to 40 ft lbs. I then tightened the u bolts to 80 ft lbs.
caseyclan
May 29, 2007 07:25 AM
greenworks
Jan 3, 2006 12:32 AM
tschwab
Oct 22, 2004 10:45 PM
Burpl
Jun 23, 2004 07:19 AM
ronster
Nov 19, 2002 08:22 PM
