Project "Extended Range"
thanks brother. was gonna call ya up but figured I would put my son to work and we spent some 1 on 1 time doing the build. he had fun.
later that day he was telling someone that the first time in his life he smelt like his dad. DIESEL! LOL 13 year olds. can't beat em so I guess I will love him lol
. If you ever need help just let me know
well did a test on the system last night. put 50 gallons in the top tank. had 1/8 tank in the bottom. started to transfer and it moves so much fuel so fast it creates a killer vacuum in the top tank (bottom tank vents thru the cap good so am ok there). SOOOO, I bought a check valve, hose and fittings and am going to drill/tap 1/8" pipe hole and install a fitting at the highest point. the check valve pops at 5psi (installed a vacuum gauge and it pops sooner which is cooler) and will keep fluid from escaping the tank (built in roll over valve
timed it for transfer and put in 3/4 tank in less than 5 minutes
). timed it for transfer and put in 3/4 tank in less than 5 minutes
good point brother. Either way i pay that to fill up. I just fill up more frequently. Setup looks good tho. Good job as always!
