H&S Towing thoughts
H&S Towing thoughts
Its finally camping time and as I use my 5er to live in while I work away from home I generally pull it all over the place from spring to fall. Finally got my first towing experience lately and I'm not that impressed with my new truck as I was with my 07 5.9L 6 speed manual, though I had that truck pushing a lot more power. My new truck is really gutless in the higher ranges, from 0-80 kph it pulls hard but the truck then has a hard time maintaining 100kph (highway speeds) climbing any hills is like pulling teeth, it won't pull its way through any gears from 4-6. I have completely locked 6th gear out and I stay in 5th to keep RPMS at 1900. This is on stock power with 315's for rubber. Im really fighting the urge to put the mild setting on my H&S but don't want to risk putting my tranny in harms way. My trailer only weighs 9,000LBS, so its not ridiculously heavy or anything. Anyone out there adding extra power on a stock tranny and having good luck?
That's too bad, I tow 10-11k on the highway with mine (all stock, 285s) and it will maintain 70-75 up 6% grades at 8,000'. Sometimes I have to manually drop into 5th (auto) on the steeper stuff - but I couldn't be happier. I mean, the thing will haul a lot of weight faster than I really should be going, so I have no complaints. It's not like I'm getting passed.
I could be wrong but I think your issue is because of the tire size that you are using with the 3:73 diff's on your truck.
I have a 08 fully deleted with a Smarty S67 ME23 on CaTCHER level 3. My tire size is LT265/70R17/E, I have been this way since Aug. 09. I towed last year in the Rockies with no issues at all. I could easily maintain 60 to 65 MPH pulling my 5er up hill. The only time I would down shift to 5th gear was when the egt's where getting high. My 6th gear RPM's when towing is around 1600 RPM.
Jim W.
Jim W.
Something doesn’t sound right; I would reload your tune and add the OD for the transmission. I have 373s and 315/70/17ATs and I don’t have any problems with power on Stock or Mild. Like I said just try and reload it.
I'm on 315s w/ 3.73s in a 2012 deleted w/ H&S on the stock setting and it tows just fine. I came from a 600+hp 03 4x4 w/ built 48RE. I would much rather tow w/ my 2012 on stock.
I think I will try and reload the tune, I haven't updated the blackmaxx since I bought the darn thing either, I will see how that goes, I agree with the tires bringing my gear ratio down but this thing should pull my trailer like nothing, its not that heavy at 9000LBS
I towed my 5er from KC to Florida last year, no issues at all, good power etc. I am about to order my MM and deletes, I plan to run deleted on stock while towing. Has anyone had head gasket issues, I plan on studs but may not have time to put them in prior to my next trip towing my 5er.
Head studs are a must in my opinion. Some may disagree, but you can get studs for a good price and they take about 5 hours to install....Well worth the investment!
I am a newbie Dodge owner. Having owned 5 previous Ford's (4-7.3's and one 6.0) I love Fords. But purchased a Dodge due to Ford just not wanting to deal with me this time. I swallowed my Ford pride and purchase a 2012 3500 dually Longhorn. Love the inter. of the truck. The ride is ok. Dodge doesn't put the same amount of metal in its Doors roof or tailgate. I gave up 4.5-5 mpg. However I have no complaint as to the way the dodge pulls. I am towing 14.5K totally stock.
Just an update on my problems I was having, I looked on the H&S website at the update list and descriptions and since I bought the programmer in january or so and hadn't updated it H&S had several software updates since then and one of them sometime in February fixed an issue with the 2012 cummins and addressed the powerless problem. I upgraded it two days ago and the truck is 10x better now. Wished I would have done the download sooner and I will pull soon hoping it'll solve everything.
Just getting back into Diesel's after a 13 yr break. Just bought a used Ram 2500 4x4 crew short bx 6.7L auto 3.73. Stock tires.
Lots of choices, so little time. We leave on a trip in a few weeks time. Aside from cold air kit, what type of tuner can I add without spending days removing stuff.
I saw the leading post by Blake, but am not sure I can just delete DPF, and do the cali- version and not wonder if the transmission will suffer?
Towing a GVWR 8200lb travel trailer and motorcycle in bed. Should not be and issue for this rig
Oh- saw something about a boost-fooler? Seems simple but what are implications?
My last was a 01 F250 4x2 7.3L and it towed stock like a mule on steroids. 22mpg at 75mph with the bed loaded.
I love this Dodge but the MPG's are a wee bit on the weak side.
How are things now??
Thanks
All in all, the programmer update did the trick, its a totally different truck and probably back to normal as it can get. Pulling my trailer isn't like pulling teeth like it was before I fixed the problem. If anyone is having the same issues be sure to update your programmer before you even think its a bigger problem. Thanks to whoever gave me that advice.
