Full delete and got a code on the Smarty jr
Old Mar 2, 2013 | 04:40 PM
budsowner's Avatar
I hooked the Smarty up to the truck and shows a p040d Exhaust gas recirculation temp sensor 1 circuit high.I clear it out and it comes back.I thought the smarty kept it from doing that.Any ideas?
Old Mar 3, 2013 | 08:15 AM
budsowner's Avatar
bump.
Old Mar 3, 2013 | 11:04 AM
6.7L MegaCab's Avatar
It could be a few different issues anywhere from wiring to the PCM. Hopefully it is none of those and simply your Smarty not being very smart lol.
Here are some troubleshooting instructions you can try, but I would return to stock first and reload your not so smart Smarty tune to see if that fixes it.
P040D Troubleshooting - See the attached PDF Instead.
Let me know if you need more help and I can see what I can dig up.
File Type: pdf
Last edited by 6.7L MegaCab; Oct 30, 2023 at 11:06 AM. Reason: Added P040D Troubleshooting PDF as the Shared Link is no longer directly accessible
Old Mar 3, 2013 | 11:08 AM
No offense intended with the "not so smart Smarty" comment. I just got home from work...and only got a couple hours of sleep last night before going in, so I was just trying to be funny lol
Old Mar 3, 2013 | 01:59 PM
tbarbee1's Avatar
How long did you run the truck before you got the code?
Old Mar 3, 2013 | 02:13 PM
budsowner's Avatar
I didnt get a check engine light.I just check the smarty and it showed that code.I dont know how long i ran it before it came on.And it wont clear it.
Old Mar 4, 2013 | 01:45 PM
tbarbee1's Avatar
Oh I see. i'm not sure what to do about it. If it were mine and I didnt have a CELand it was running fine...out of site out of mind.
Old Mar 4, 2013 | 04:04 PM
budsowner's Avatar
I think its defueling some.I thought the smarty kept from having any codes.
Old Mar 14, 2013 | 03:13 PM
Booboo's Avatar
does your delete pipe have bungs to plug the sensors into cause my flo pro did not and i get the same code sometimes as far as the defuleing mine does it some also
Old Mar 14, 2013 | 04:03 PM
budsowner's Avatar
No mine dont have the bungs.But its the smarty i called they gave me a beta for now it helped some but didnt completly fix it.So i bought a h&s and that fixed it.
Old Mar 17, 2013 | 08:09 PM
FNHEAD's Avatar
Just did my deletes, wrapped it up today. Had the cts up and running before I started and checked codes yesterday, had none. This afternoon I programmed the truck and did everything needed and went for a drive. Everything seems to work great but I did another code read on the cts and got the same code as you mentioned. P040D. I thought the smarty was supposed to take care of that?
Old Mar 18, 2013 | 04:41 AM
budsowner's Avatar
They are workung on a fix.
Old Mar 18, 2013 | 09:19 AM
FNHEAD's Avatar
Did they mention any time frame for the fix?
What does it mean as far as driving the truck while it is throwing this code?
Thanks
Old Mar 18, 2013 | 09:31 AM
budsowner's Avatar
Nothing really but it will defuel some.
Old Mar 18, 2013 | 07:49 PM
FNHEAD's Avatar
been on the phone with mads and they are having me try a few things...
reloaded the program when the truck is at operating temperature - did not fix the code
plugging the egt sensor back into the connecter by the egr valve - fixed the code but thru another code
plugging the egt sensor back into the connector by the downpipe - did nothing but thru the original code
seems like nice guys and will call them tomorrow and see what they come up with.
