DPF Delete
Old Sep 4, 2013 | 02:48 PM
LB164's Avatar
DPF Delete
Getting ready to delete on my 2011 2500. h&s mini maxx. Any more suggestions??
Old Sep 4, 2013 | 08:58 PM
brophyn70's Avatar
what type of suggestions are you looking for? install, or more tuner suggestions?
Old Sep 5, 2013 | 09:15 AM
LB164's Avatar
Just want to make sure its done right. This will not be done by me, but by the pro's. Im gonna keep the 4" stock pipe but will delete from the turbo to the muffler and will use a H&S Mini Maxx to handle the codes. Just looking for any other advice that may be helpful to me as I go through this process.
Thanks!
Old Sep 5, 2013 | 09:58 AM
Beast2B's Avatar
If you plan to use the additional power aggressively, look into head studs to keep the head gasket tight. If you,re staying near stock power and driving for mpg it isn't much of a problem.
Old Sep 12, 2013 | 12:14 AM
T210DRVR's Avatar
Don't allow Dodge to do any ECM updates. The latest update can lock out the tuner and will make your investment worthless. Worse, you'll have to reinstall all the deleted equipment.
Old Sep 12, 2013 | 01:02 PM
LB164's Avatar
Thanks a lot for the advice. I will deff keep that in mind!!
Old Sep 13, 2013 | 01:31 PM
Busboy's Avatar
I would also change out the factory intake and boost tube for a H&S one this will avoid buying the egr valve delete part and you will only need the EGR cooler delete. While you are at it also remove the crankcase vent pipe from the intake to the turbo and block it off, run a 4 foot piece of 3/4 heater hose from the crankcase to down by the frame rail on the pax side. While I like the overhead mount for the mini max as it is out of the way and blends in well I now find it difficult to read with sun glasses on. My son on his 2011 had his mounted to the center dash at a slight angle and found it better. When plugging into the OBD2 port remove the obd2 port and invert it back into the same spot it may be necessary to free up a little wire to do this but with it upside down it gets the mini max adapter up and out of the way and makes the port inaccessible unless the panel is dropped so not as easy to hook a scanner to. You should plan to monitor the EGT and the usual place is in the exhaust manifold just before the turbine but if you do the EGR COOLER delete the rear plate can be drilled and tapped on the bench and avoid possibly braking a tap in the exhaust manifold. Don't forget to update the tuner I would also recommend getting the H&S transmission tuning if you don't you'll see why after you have deleted.
Old Sep 17, 2013 | 01:08 PM
LB164's Avatar
Wow. All sounds great. Never knew owning a diesel would be so costly...lol I love the truck tho. Im working on it one step at a time...
Old Sep 28, 2013 | 07:54 AM
nvr-enuf's Avatar
Hello everyone
Looking to delete 2012, I found some h&s mini max for sale - some users say "this is the one you want". Is there a specific h&s part number or part number and mfg date that is best /desired? I do not need any more power, just clean engine and mpg
Thanks
Old Oct 3, 2013 | 02:27 AM
mdub's Avatar
Has this really been confirmed that Ram released a tune for the original poster's 2011 truck that would no longer work with H&S?
I understand 2013 trucks no longer work with H&S tuners, but I was not aware of any confirmed problems with 2012 or older trucks. Seems kind of important to clarify for those that might be interest in used trucks.
Old Oct 4, 2013 | 12:14 AM
T210DRVR's Avatar
The diesel tech at my local Dodge dealer confirmed that the latest flash will somehow lock out the tuner. He suggested that I place a lock or some kind of warning on the ODB port to alert any Dodge dealer NOT to reflash the ECM. Mine has a pending update for the ECM but when he saw my missing equipment he politely suggested I decline Dodge's offer because of the issue.
I doubt that H&S will confirm that issue as they are really touchy about the DPF delete issue. I would be touchy too if one of my competitors was almost fined out of business by the Feds.
Old Oct 4, 2013 | 07:25 AM
Mechanos's Avatar
Please, someone correct me if I'm wrong, but it was my understanding that as long as the ECM is running a stock tune at the time of the update flash, you can then reflash with your performance tuner. The issue arises if a non-stock tune is detected at the time of the update flash... then the ECM will be locked out.
Old Oct 9, 2013 | 03:23 AM
rich's Avatar
if you load any tune into a ecm it is no longer a stock tune and you will have a vin locked tuner. Raceme has a good tuner for a lot less then H&S. doesnt do as much, but is affordable. Runnning one on my wifes 11..
Old Oct 19, 2013 | 07:39 AM
blacksmoke's Avatar
rich how do you like the RaceME tuner? I have 2012 3500 have been looking at RaceME but don't know anything about them. Could you please give me some info on them, likes and dislikes.
blacksmoke
Old Oct 20, 2013 | 12:34 AM
rich's Avatar
Installed it on my wifes 11 and it has been great. Granted it isnt as fancy as H&S but it cost a lot less too. Looks very similiar to a smarty to.
