Arp studs
Old Apr 11, 2012 | 09:45 PM
dieseldog123's Avatar
Arp studs
GETTING NEW 2012 3500 IF I DON'T WANT TO DO CRAZY MODIFICATIONS AND JUST RUN THE MINI MAXX WITH THE DELETES DO I NEED TO DO HEAD STUDS LIKE 425S OR 625S. I HAD 800FT LBS IN MY LAST TRUCK AND THAT WAS PLENTY.
Old Apr 12, 2012 | 09:21 AM
strtlegal's Avatar
It's not necessary with the H&S tunes unless you start messing with hot unlocks. It's precautionary but not needed unless you are really feeling the need for more power.
If you do get them 425's are all you need.
Old Apr 12, 2012 | 12:21 PM
thanks for the reply
Old Apr 12, 2012 | 12:37 PM
Big Swole's Avatar
"Swole It like ya Stole It"
Or spend NO money and just time.
Pulled each stock head bolt, one at a time.
Lube with ARP stud/thread lube (includind underside of bolt)
Torque back to 100 ft. Lbs.
Once all are done.
Start in the middle, working your way out in a circlular pattern.
Take them up in 5 ft. Lb. incriments. Give 10 min cool time between each incriment.
Take them all the way to 135-145 ft. Lbs.
Done!!
No $ spent and will hold just fine.
Old Apr 12, 2012 | 07:26 PM
New2Diesel's Avatar
"Gomer Pyle"
Easy install all the way!!! I paid someone but that was because I was deployed. I got 625's because I needed them
Old Apr 13, 2012 | 03:14 PM
unit74's Avatar
Nobody stops at just a tuner....you say that now, but the itch will get you.
Do the studs. You can also look into H11 studs as well.
Old May 5, 2012 | 03:20 PM
rhollenbeck's Avatar
What sequence did you remove the studs and retorque to 100 ft lbs?
Old May 5, 2012 | 04:52 PM
Big Swole's Avatar
Start in the middle of the head and work your way out in a circular motion.
Same for takin them up from there in 5-10 lb. incriments.
Old May 9, 2012 | 10:06 AM
Mike Holmen's Avatar
The Guru
Nothing wrong with just retorquing the stock head bolt up to 125ft*lbs. The stock stuff is pretty good for stock stuff. Its probably almost the same tensile strength of arp425's.
Some guys have gone as high as 135ft*lbs, but I've done 125ft*lbs
Don M
32
May 12, 2006 02:37 PM
James Lucas
Jun 13, 2005 08:46 PM
AK RAM
15
Apr 5, 2005 11:25 PM
BARTMAN
Mar 24, 2005 04:59 PM
jermey1980
27
Feb 27, 2005 06:11 PM
