After deleting
Old Apr 23, 2012 | 02:15 PM
redneck1's Avatar
After deleting
It has been 1,000 miles since I did the Cali delete on my Mega. Here are the things I have noticed since deleting:
1. Fuel economy has imrpoved from 17.8 l/100km (per evic) to 13.3 l/100km (per evic). This has probably been the single greatest improvement.
2. EGT is lower, I am averaging around 625, 700 at 60 mph.
3. No regens
4. better throttle response
5. reduced performance from eb (was expected)
6. occasional puffs of black smoke
The last point has me in a bit of a puzzle. After running the truck if I shut it off and restart it before it fully cools, It feels like as if it is not getting enough air. That is when I notice the smoke. I am not smoking out the heghbiourhood, but it is noticable in the side mirror. Perhaps the TV is sticking?
Also under heavy acceleration sometimes I'll notice a reduction of power, similar to defueling or not enough air type sensation. With this condition there is no smoke.
I am not sure if this is normal with the cali style delete. The truck is not throwing any codes and the Smarty is set to SW 1.
Has anyone else experienced the same thing?
Old Apr 24, 2012 | 05:56 PM
Gry113500's Avatar
I have the same set-up as you do, and occasionally I've noticed the lack of power too. I've always just reloaded the program and it's back to normal. Yesterday I unplugged the EGR and TV and the EB works awesome again! Not sure if this will cure the sudden power loss issue, but at least the EB works as its supposed to. I'll keep you updated if it fixes the sluggish feeling.
Old Apr 24, 2012 | 06:30 PM
redneck1's Avatar
So you just run with the EGR plug off? I guess it's easy enough to erase the codes. I'll try it too, thanks. This might be a stupid question but can the TV be gutted?
Old Apr 24, 2012 | 09:26 PM
Gry113500's Avatar
Yep, EGR plug zip tied out of the way, and no CEL so far. I dont think you can gut the TV. You can buy a TV delete. Both Shibby and Glacier make really nice TV delete set up's for under $80 if I remember correctly.
Old Apr 25, 2012 | 12:33 PM
SOhappy's Avatar
If you're worried about the TV closing you can take the cover off and remove the white nylon gear. A spring keeps the valve open. It's my understanding that the software should keep it open anyway.
Old Apr 25, 2012 | 02:39 PM
RunningM's Avatar
I have about 10k since I did the deletes and have been reloading my tune every week since to deal with the loss of power. Here is what I have been told:
1. This issue only impacts manual (G56) pickups.
2. In 2011 Chrystler added a low fuel pressure sensor which is creating the issue
3. The only known solution is to add an after market fuel pump to keep fuel pressure up.
Have any of you heard this?
Old Apr 26, 2012 | 12:28 PM
redneck1's Avatar
This is the first that I'm hearing of this. I don't understand why the G56 trucks would have a low pressure switch and not autos.
On another forum some individuals were unplugging their egr and tv after delete to deal with the power loss issue with some success. I`ll be trying that later this afternoon when I drive the truck. I`ll post the results.
My understanding is that smarty does not require the disconnect of egr or tv as the programming takes care of those functions so I am curious to see what will happen.
Old Apr 26, 2012 | 06:24 PM
Gry113500's Avatar
My truck has a 68rfe, so that dispells that myth. I thought you could leave the egr and tv alone on 4th gens too, but I think it varies from truck to truck. Mine has been working flawless since I unplugged that crap
Old Apr 26, 2012 | 07:50 PM
redneck1's Avatar
It's raining like mad here so I didn't unplug it, but I'm feeling that you're probably right about unplugging. I've been playing around with the truck a bit and when I start accelerating (especially in 3rd and 4th gears) when I hit 2,200 to 2,400 rpm the truck feels like it's not getting enough air or fuel. You no longer get pushed into the seat, but instead it accelerates very slowly. Also at 50 mph in 5th gear if you mash the throttle boost gets to only 22psi and acceleration is almost non existent. Feels like something is holding back the truck. Either way it doesn't smoke heavily, but just a little bit. More or less like my stock 03 did when I stepped on it in 4th.
Now, I installed the gauges before I deleted to get a bit of a baseline for boost and egt. Anytime the regen was on egts were very high, but there was no boost. To see anything you had to really step on it. Once the regen was done boost went back to normal, which probably has something to do with the tv.
I'm thinking that as the TV and EGR is connected, even though the smarty electronically shuts them off, the TV and EGR are in all likely hood active.
You also mentioned that once you disconnected the tv and egr the EB started working better. I wonder what eb function folks with complete deletes are experiencing.
Old Apr 27, 2012 | 03:49 PM
redneck1's Avatar
So I disconnected the egr and tv this morning and went for a drive, about 40 miles. This is definitely the way to. No power loss, better throttle response and boost builds much quicker. So although smarty does not require a disconnect of the egr and tv, my truck runs much better with those two item disconnected.
Old Apr 30, 2012 | 01:52 PM
SOhappy's Avatar
... Also at 50 mph in 5th gear if you mash the throttle boost gets to only 22psi and acceleration is almost non existent. Feels like something is holding back the truck. ....
Ahhhhh, the mysteries of software. That's EXACTLY what my truck does stock (no deletes yet) with the EGR unplugged. It sucks because that's right about when you need the power the most for passing on two-lane highways *
*there was no "I think I wet my pants" icon so I had to with "yuk" instead.
Old Apr 30, 2012 | 01:53 PM
SOhappy's Avatar
Report back in a week. Stock, the loss of power returns after awhile. Hopefully it won't on yours....
Old May 1, 2012 | 07:07 PM
redneck1's Avatar
It's been a few days now. The eb is working flawlessly. Power wise it's still good, but it does feel like it's starting to hold back a bit. Maybe mother Chrysler played a joke on us an installed electronic counter measures for Smarty users?
Anyhow, if she continues as she is now I'll be ok with it. I only have it set to SW1. Down the road I want to loose the egr cooler and tv so I wander if anyone that has a full delete experience the same power loss using a Smarty as some of us experience with a Cali deletew?.
Old May 2, 2012 | 04:29 PM
Gry113500's Avatar
glad to hear it worked for you too! I run SW3 and timing 2 on my truck and it pulls hard and feels pretty quick, considering it weighs almost 8,200lbs with me in it
Old May 2, 2012 | 05:20 PM
cfdlighthouse's Avatar
I just finished the full deletes last week dpf, throttle valve, egr and cooler....also have the smarty set on 1 and have had no issues with power loss, put 500 miles on since finishing and the truck is alive with power just on the standard setting and got 20 mpg hand calculated on the highway crusing at 70....
so maybe the complete removal is the answer?
good Luck
