4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Upper rad hose
Old Dec 15, 2013 | 09:17 PM
Mikes2002Ram's Avatar
Upper rad hose
2011 6.7 with deletes sucking upper rad hose closed. Thermostat tested in boiling water it works fine what is the possibility of the cap being bad. HG would have psi. Not vacuum in it. Like it's not pulling in coolant from reservoir tank
Old Dec 16, 2013 | 09:28 AM
Busboy's Avatar
There is not enough coolant in the system.
Old Dec 16, 2013 | 01:53 PM
Seriously. I burped it and removed vent plug. Also ran fine. Next day it sucked upper rad hose closed Craziest thing ever. Possibly a air lock ??
Old Dec 16, 2013 | 02:02 PM
jhenson's Avatar
Check the system cold and double check that radiator is full. Other than that I'm at a loss. The cooling system "sucks" from the bottom of the radiator......hence the spring in the lower hose. The upper hose is pressurized....have no idea why it would be collapsing.
TxDiesel007
Oct 13, 2012 04:32 PM
thrashingcows
Nov 12, 2011 01:51 AM
brentbiely
Dec 7, 2009 10:22 PM
robert78.5
Dec 28, 2008 03:24 PM
