4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
traction control
Old Jan 16, 2015 | 07:09 PM
overhill07's Avatar
traction control
Is there a fuse I can pull to disable traction control? It kicks my cruse control off. Dealer is clueless.
Old Jan 17, 2015 | 06:53 AM
BigIron70's Avatar
Cummins Guru
Why not just turn it off using the switch?
You may have another issue it shouldn't kick your cruise off.
ESP Partial Off
This mode is entered by momentarily pressing the ESP OFF switch. When in "Partial Off" mode, the TCS portion of ESP, except for the “limited slip” feature described in the TCS section, has been disabled and the "ESP/TCS Indicator Light" will be illuminated. All other stability features of ESP function normally. This mode is intended to be used if the vehicle is in deep snow, sand, or gravel conditions and more wheel spin than ESP would normally allow is required to gain traction. To turn ESP on again, momentarily press the ESP OFF switch. This will restore the normal “ESP On” mode of operation.
Old Jan 17, 2015 | 10:53 PM
overhill07's Avatar
It also does it when switched off.
thank you for detailed answer. I will try to figure it out tomorrow.
Old Jan 18, 2015 | 11:13 AM
overhill07's Avatar
Big iron 70, no esp button on my dash? There is a traction control button. It's either on or off. Cruise will kick off after about 15 min on either setting. Then both little traction control lights will be on . Cruise won't work again until you pull over and shut engine off . When you restart you are good to go until next time. Dealer says shows no code, sorry.
This truck has been to the dealer more in 1.5 years then my 2002 was in for the 11 years I owned it.
Old Jan 18, 2015 | 07:18 PM
Busboy's Avatar
What year truck and what kind of transmission do you have?
Old Jan 18, 2015 | 09:00 PM
overhill07's Avatar
Truck is a 2013 with the 370 hp Cummins and automatic transmission. Not Aisen.
Busboy
22
Mar 14, 2014 07:52 AM
JOE M
Jan 13, 2014 06:05 PM
dr450r
Oct 17, 2012 11:34 AM
mhuppertz
Oct 20, 2008 04:16 PM
TexasDiesel
Dec 27, 2002 10:47 AM
