4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
tires
Old Dec 8, 2012 | 04:47 PM
skirk55's Avatar
tires
My 2011 ram 2500 longhorne diesel 4x4 needs tires. Stock 235x75r17 needs more tire! I was looking at 285x70rx17 will they fit?
PHP Code:
[PHP]
[/PHP]
Old Dec 9, 2012 | 09:10 PM
Hoss's Avatar
Thats MR Hoss to you buddy!
Yes.
Old Dec 10, 2012 | 02:03 PM
SOhappy's Avatar
PHP Code:
[PHP]
[/PHP]
I'm running 285-70/r17s (Hankook Dynapro) no problem. In fact I wish I'd gone with 305s or even 315s to fill out the wheel well a bit more. I have a 2" level and airbags but still.... you'll be fine even stock.
Old Dec 10, 2012 | 09:18 PM
gdavidg's Avatar
Smile
Looking at the tire size you stated were on your truck I assume you have a dually??
ON my SRW I fit 285-70-17 on stock rims with no rub. And others are running 295-70-17 with no rub and no lift.
Old Dec 11, 2012 | 05:33 PM
skirk55's Avatar
No a single wheel. There is alot of room to fill in. I pull a fifth wheel and I just want more tire!
Old Dec 11, 2012 | 08:22 PM
gdavidg's Avatar
With SRW 285-70-17 fits my 2010 great. I am using Toyo Open Country AT's E rated at 3750 pounds. Drive great, have heard tire wear is not so great. Just wanted safety first with cost a secondary issue. With a camper was running pretty heavy on the rear tires, with a 5ER you likely will be up in rear axle load also.
Old Dec 12, 2012 | 02:20 PM
SOhappy's Avatar
Oh, and it's my understanding the Powerwagon comes with 285-70/r17s, so it's not like the truck can't handle them (whatever that's supposed to mean...)
Old Dec 12, 2012 | 03:11 PM
palomino's Avatar
285/70r17's are like going from a 3.73 to a 3.42 axle ratio. I personally like it better than the 265's my truck came with.
Only thing I wish I did was go with the Nitto Dura Grappler 285/75r17..
Old Dec 12, 2012 | 06:24 PM
skirk55's Avatar
Did your MPG go down much? I pull a 12,000 fifth wheel now and the truck pulls with plenty of power now. I do not want to loose that.
Old Dec 13, 2012 | 01:28 PM
SOhappy's Avatar
In my experience is the 6-speed auto tranny must compensate some for the larger tire size. On my 3rd gen with the 4-speed auto I lost 2mpg going to 285s from the stock 245s. On the new truck there is no difference in mpgs with the bigger tires, empty or towing. Both had 3.73s.
By the way, I turn 1800 rpms at 75mph with this truck, old truck was 2100 rpms.
Old Dec 13, 2012 | 06:22 PM
skirk55's Avatar
Thank you for the help.
Old Jan 1, 2013 | 10:31 AM
skirk55's Avatar
I need a tire that is good in mud/snow and Eraited I Pull a fidth wheel. Nor too much road noise we drive for days straight!
Old Jan 2, 2013 | 01:31 PM
SOhappy's Avatar
I need a tire that is good in mud/snow and E rated I Pull a fifth wheel. Nor too much road noise we drive for days straight!
The Hankook Dynapro AT/M fits that description, and wears well too. Had them on the last two trucks, very satisfied.
Old Jan 5, 2013 | 04:08 PM
tpollon2's Avatar
290/70/17 's will fit
PHP Code:
[PHP]
[/PHP]
Hankook Dynapro ATM's -------- Awesmoe all around tire in every condition
Old Jan 5, 2013 | 09:23 PM
NE frmhnd's Avatar
Weigh about twice what your average tire weighs as well. Very tough tire. Run them on everything at work for puncture resistance.
