4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Shutdown timer
Old May 16, 2014 | 08:14 PM
timk006's Avatar
Shutdown timer
Wondering if anybody has had experience with having the OEM shutdown timer activated. I cant seem to find much info available.
It says it can be set for 5 minute increments. That seems fine for heavy towing, but are you stuck with the min 5 minutes on every shutdown. Or, is there a way to switch it off for daily driving?
oh, 2014 3500
thanks
Old May 19, 2014 | 09:18 PM
jadocs's Avatar
Never heard of this feature. I have a 2014 2500, is this only on 3500's?
Old May 19, 2014 | 09:22 PM
timk006's Avatar
I was reading one of the electronic owners manual, I believe it was in 2500 3500 diesel supplement. It had to be dealer enabled.
Old May 19, 2014 | 09:33 PM
jadocs's Avatar
I'm curious now. I'm going out to my truck to check it out.
They say the "high idle" needs to be dealer enabled, but mine worked when I tried it.
Old May 19, 2014 | 09:35 PM
timk006's Avatar
My high idle worked right off the lot. Don't know where you would turn on the shutdown timer.
Old May 19, 2014 | 09:54 PM
jadocs's Avatar
Just came back in. Best I can tell is it's accessed through uconnect at the following path:
Apps/settings/engine shut down
The only two options I have on that menu are... how long power remains on after shutdown, and how long the lights stay on after shutdown.
Reading the recommended idle based off driving conditions, 99% of the time 2min would be max like you said. I imagine that you could set this feature to "0" (ie. off).
I'm going to request this feature when I take my truck in to get the tire pressure sensor replaced.
Old May 19, 2014 | 09:56 PM
timk006's Avatar
Let us know what you find out.
Old May 19, 2014 | 09:57 PM
jadocs's Avatar
Will do. Should be soon since they ordered the part last week.
Old May 29, 2014 | 07:11 AM
jadocs's Avatar
Sitting at the dealer now and they said they would see what needed to be done in order to enable it.
Old May 29, 2014 | 11:43 PM
jadocs's Avatar
So here is the deal on the idle shutdown. It's actually the time that you can have the dealer adjust for shutdown after a remote start. It is not a turbo timer. In other words it does not keep your engine running after you shut down and take the key out. It's simply for how long it remains at idle after a remote start.
Old May 30, 2014 | 02:41 PM
timk006's Avatar
Oh well, but thanks for the update.
Old May 30, 2014 | 09:15 PM
jadocs's Avatar
No problem
sr148
Dec 5, 2005 07:52 AM
joelsepf
Nov 11, 2005 08:34 PM
trik396
Jul 7, 2005 12:41 PM
marka
Mar 30, 2005 05:12 PM
PumpDaddy
Sep 26, 2003 07:25 PM
