question on dually trucks
I have a 2011 cab/chassis 3500 4x4
the truck seems to wander a lot. so much so that it is annoying. it seems to do this at all speeds. i am curious is this normal for duallies or do i need to get it checked out. I just checked pressures and rotated the tires and if anything it seems worse. I am wondering if there is any thing to check or do before i get an alignment. any known problems? thanks
Wow, they can sell you one, but not service it???? I think I'd find another dealer. It,s bad enough that we find techs that think a power step modual is a 'programmer' and want to void a guys warranty, but to not be able to do an alignment. Ugggh
funny thing this is the good dealership around here. unfortunately i have had nothing but bad experiences with any other dealership in my area. they are all sheisters. 1 has closed its doors thankfully. Around here the only good dealers are ford's.
I don't know how many miles are on your tires, but new tires can do what your describing. When I put new tires on my 2010, I put factory oem tires on and the truck was terrible for the first 3000 miles. My 2012 came with the same tires again and no problems.
one other thing that was strange is that the inside of the front rims looks as though the calipers has worn the paint off of the rims both sides. has anyone else had this happen. i need to paint them as it is down to bare metal. not a big deal but never seen this before.
here is a pic of 1 of the front rims. they both look like this. the dark spots are primer and bare metal. it hasnt dug into the metal mostly surface. really wondering if this is normal as every time i rotate i will have to paint.
That would be a trick.
