F/R Diff Fluid
Here is a site that provides fluid capacities and type of fluid for your 2500.
http://www.amsoil.com/mygarage/vehic...=2011+RAM+2500 PICKUP+L
You will need a funnel to fill up the differential with the standard cover.
Jim W.
Jim W.
Now as far as oil weight this depends on what you are planning on doing with the truck. Will you be hauling, towing an such; then I would use as a minimum, Sever Gear 75W-110 synthetic oil. Some owners have been using Sever Gear 75W-140, this oil is for extreme use such as towing 8 to 10 hours a day, 6 days a week and 50 weeks a year.
Jim W
I just did mine, I'm using 75W90 castro full synthenic, seems to work good. Been using that stuff in my older truck for years now. I also threw on a mag-tech transmission pan to speed up oil servicing.
I got 40000 miles without the oil getting dirty in the diffs/T-case/RFE68
Just a tip that I learned a while back, since I wind up doing this job on our jeeps and the truck: when I take the cover off, I use a can of carb cleaner and spray the snot out of the inside of the center section, then let it drain out and even use a rag to get it all out. It helps remove the aforementioned metal shavings and evaporates so it doesn't leave a residue. Good stuff!
afate45
Jun 7, 2014 12:08 AM
banana
Dec 1, 2009 11:44 PM
icrider
Sep 27, 2006 03:10 PM
