4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
The Exhaust Brake
Old Sep 27, 2010 | 06:57 PM
howe719's Avatar
The Exhaust Brake
So I really like the exhaust brake, really helps with stopping. Overall would it be ok to have it on all the time even for short trips etc...? Does it have an effects on the life of the motor? would it hurt the motor etc...
Thanks for any input.
Old Sep 27, 2010 | 08:11 PM
signature600's Avatar
I run mine on all the time...always in tow/haul as well!
Chris
Old Sep 27, 2010 | 09:23 PM
djcheez's Avatar
no it wont hurt. some say it is good to run all the time to help keep soot from building up on the vanes. Some also say dont run it in slippery conditions .
Old Sep 27, 2010 | 09:44 PM
capt.Ron's Avatar
I think I can... I think...
Chris
Wouldn't that reduce fuel mileage?
I thought tow haul just kept the tranny from shifting beyond 5th gear.
Old Sep 27, 2010 | 09:51 PM
djcheez's Avatar
tow haul just changes shift points and more aggressive downshifts with the EB, doesnt limit high gear like previous years. perhaps there might be a slight mpg loss but i doubt much worth noting.
Old Sep 27, 2010 | 09:59 PM
Colo_River_Ram's Avatar
With age comes the cage
Does the EB switch turn off with the key? My 5500 will still be on at the next start up. It saves you from having to turn it on with each start up.
Old Sep 27, 2010 | 10:02 PM
djcheez's Avatar
yes it turns off with key for safety reasons. have to turn it o each time after startup.
Old Sep 27, 2010 | 10:11 PM
That is programmable by the dealer if you desire the on setting..
Old Sep 28, 2010 | 11:33 AM
I have 3.42 gears, and the 68RFE...5th gear is like an old truck with 4.10's...
Either way, no, it still uses 6th, but shifts firmer, and downshifts farther with the EB. I wish I could get it to shift firmer yet, I was used to a DTT 47RE with 210psi line pressures
Chris
Old Sep 28, 2010 | 01:25 PM
capt.Ron's Avatar
Chris
Well I may have to start running the tow-haul setting then!!
Old Sep 28, 2010 | 07:00 PM
howe719's Avatar
Could somebody please explain how the brake works. I understand there is a flip that closes and puts back pressure against the cylinders but some times there is just the noise of the engine slowing down and sometimes there is a loud whisle noise from the turbo. IS this ok. Is the turbo spooling up in the backwards direction to help slow down or what???
just would like to know more about this thanks
Old Sep 29, 2010 | 12:06 PM
netomh's Avatar
The EB uses the Variable Geometry Turbo. Instead of a "flip" closing, it partially closes the nozzle on the exhaust side of the turbo. This has two effects - it increases the backpressure in the cylinders, but it also causes the turbo to spool up due to the increased air velocity through the narrower opening. This second "effect" is actually the main point of the VGT - allows faster spool-up at lower engine speeds. It also explains the whistle - it's just the turbo spooling up. You don't normally hear it so loudly because the engine noise masks it somewhat during acceleration.
HERE is a pretty good explanation of the VGT & nozzle, along with an animated diagram that shows how the VGT setup works.
Does that help?
Old Sep 29, 2010 | 04:33 PM
howe719's Avatar
yeah that is great thank you so much
Old Oct 2, 2010 | 09:34 AM
Skyd Ram's Avatar
Chris
The "Overdrive" trans tuning from H&S firms up the shifting and gets rid of some the gear hunting. It will be avaiable through a stand alone tuner for the guys that don't want to run a full power/delete tuner.
Old Feb 19, 2011 | 09:48 AM
jmul's Avatar
i have searched the forums trying to find out how to make the switch stay on with out cutting it on and off for my exhaust brake, i thought i had read a article with photos on how to do this and cant find it. if anyone knows where it is please reply. thanks,
On my Dodge 2010, 2500, 6 speed manuel, 4x4, big horn cummins.
