4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Difference in transmissions
Old Jun 21, 2016 | 07:56 PM
Jimhi's Avatar
What is the difference between the Aisin and the G56 transmissions. I am looking at a 2016 Dual rear wheel and the sales person is saying he prefers the G56
Old Jun 21, 2016 | 08:20 PM
gsbrockman's Avatar
For example.....
Crew Cab 4x4 DRW LWB Aisin 3.42 has a GCWR of 29,300 lbs. and can tow 20,510 lbs.
Crew Cab 4x4 DRW LWB Aisin 3.73 has a GCWR of 33,800 lbs. and can tow 25,010 lbs.
Crew Cab 4x4 DRW LWB Aisin 4.10 has a GCWR of 39,100 lbs. and can tow 30,310 lbs.
Crew Cab 4x4 DRW LWB G56 3.42 has a GCWR of 24,300 lbs. and can tow 15,610 lbs.
Crew Cab 4x4 DRW LWB G56 3.73 has a GCWR of 26,300 lbs. and can tow 17,610 lbs.
https://www.ramtrucks.com/assets/tow...ing_charts.pdf
The Aisin is a medium duty transmission connected to a true medium duty diesel engine.
Old Jun 22, 2016 | 12:02 PM
marathon's Avatar
Aisin trannys are available only in 3500s, SRW and DRW, and come with 385hp/900 ft-lb engines.
G56 trannys come with 350 hp/660 ft-lb engines.
Higher numerical value rears, 4.10's, pull more than lower rears, 3.73 & 3.42. But the lower rears should get better MPGs.
G56s were the preferred trans for jobbers and such over the old 4 speed autos and the current auto, 68RFE.
I've heard nothing but good things about the Aisin, while the 68RFEs seem to need rebuilds after 110K or so.
I love to row my own gears (you can see my sig below) and that's what I would pick. The G56 never seems to break down but does need clutches some where around 150K. That's not all that expensive to fix, $2000 or so for the stock replacement.
For you, I guess it boils down to how much you need to tow.
Nicholas
Dec 29, 2002 07:17 PM
danlit
Dec 8, 2002 11:42 AM
frankross
Dec 7, 2002 01:21 PM
boughtadodge
Dec 6, 2002 01:11 PM
