4500 / 5500 - Chassis Cab Trucks Talk about your commercial trucks here. We realize there are differences with these compared to the regular pickups, so we have provided a place to discuss the commercial versions only.
2012 5500
Old May 1, 2013 | 12:21 PM
lnt-1000's Avatar
O.K. so there are no 2013 5500s out there to compare fuel mpg. How About 2012 5500 with 4:88 and asian auto ?
Old May 7, 2013 | 01:27 PM
Jordan5687's Avatar
I have a 4500, and 4:44 rear with aisin. Its hard to get 13mpg empty. And that's even with deletes.
Old May 8, 2013 | 04:12 PM
ridofpwrstroke's Avatar
what kind of bed do you have on it and what size tires? I am going to be running 4.88's with 36" tires with the auto on my 13 5500. 2000 rpms at 70 mph plus a single rear wheel pick up bed.
Old Jun 4, 2013 | 09:21 PM
Jordan5687's Avatar
225/70 19.5, I have an 11.5' bramco hydraulic bale bed, the bed is awesome.
Old Jul 3, 2013 | 05:15 PM
I only have 500 miles on the truck and still working on it. I have put the bigger tires on it and have not calibrated the speedo, and I got about 10.5 on first tank. That is uncalibrated speedo. By next week, I should be done with it and then I will be able to check some numbers. I was hoping for better.
Old Dec 23, 2022 | 10:19 AM
ronnyasher's Avatar
Any of you guys still running these trucks? I have a 2012 5500 and trying to determine if the converter is locking like it should. It has an ATS converter and a few valve body upgrades and shifts pretty good. No idea if previous owner had the whole tranny done from ATS or not. It says I have a permanent code p2757 that will clear but comes right back. Sometimes the light will stay away for a whole trip but says it’s pending on the scanner. Also what TCM part numbers are in your 2012? I think my truck might have a 2011 TCM on it.
Old Jun 7, 2023 | 08:57 AM
RanniWins's Avatar
It looks like there aren't any 2013 Dodge Ram 5500 models around to compare fuel efficiency. But I managed to get a 2012 Dodge Ram 5500 with a 4.88 gear ratio and an automatic transmission through an online auction using the Auction Streaming Vehicle Inspection Report, which had info on its fuel mileage. It's definitely worth checking out!
papasam53
Jul 13, 2015 06:28 PM
mechrisme
0
Sep 10, 2012 07:51 AM
Wulfdiesel
22
Oct 21, 2007 06:19 PM
RamThatStroker
May 29, 2003 07:38 PM
