Would you recommend this lift kit?
#61
If later on down the road I wan to change the rear blocks to leaf springs, how hard of a job is it?
I have been getting mixed reviews of the Tuff Country kits. I called another shop in the Houston area and without even telling the guy what kit I was thinking about he told me that he wouldnt run a Rough Country or a Tuff Country kit. When I asked him what was wrong with them he said they are just cheap kits. He said they have best luck with Superlift kits on Dodges, FabTech on Chevy, and BDS on Ford.
#62
These are the two set of wheels I am looking at. Both have same backspacing (5in) both have same offset (0) same size and width (18x9) The first one is rated at 3400lbs and the second is rated at 3200lbs.
Which of the two do you guys like more?
#63
Unless they can give you an actual reason why Rough Country or Tough Country is no good, I wouldn't really pay attention. Maybe they don't make as much on them, because they are lower priced.
#64
Those XD's are nice rims for sure
#65
They get a bad rep because their older kits always came with big spacers which yes is cheap. But tell me this, if Superlift is so good, why is my dual steering stabilizer rusting like crazy after 6 frigging months? And the Tough Country parts look like I just put them on. Also heard of huge problems with Superlifts springs sagging. Putting on new leafs and changing out blocks isn't much work, maybe a few hours.
How much of a difference would you say the rating on those wheels makes? I know the tires I am looking at are rated over both of those wheels.
Edit: I just called and talked with one of the guys at TGC. He was way cool. He answered all my questions, and actually helped me save 237 bucks. He told me that unless I go with an 8in lift there is no need to get an aftermarket track bar. He said they drop bracket is all you need to realign everything. So for the 6in kit with coils, Bilstein shocks, dual steering stabilize with Bilstein shocks shipped to my door he said 1384. That’s a hell of a deal. That give me extra money to buy other parts that I would still need if I went with a different kit. Man oh man, decisions.
#66
They are going to make the same amount. When I called I asked how much to have a lift kit installed that I bring in. The only one that I told what kind I was getting was the 4wheelparts guy. The other two guys said that they wouldn't do those kits without me mentioning the name. I wish I had more experience with this. It puts me between a rock on a hard place. With this being my first time lifting a truck I hate to try and save a little money by going with a "cheaper" kit, but I have learned though other hobbies that in the end I would have been fine going with the none name brands. I know that it saves me alot of money if I do, I just don’t want it to cause problems.
Yea just because it's a big name like KORE and a big price tag don't mean anything. I would never let another KORE product touch my truck, they are very very overrated. Tough Country seems to really make good stuff.
#67
I am getting about fed up with all the run around just to get a **** lift kit installed. I called 4wheelparts my self from japan today becasue the guy never called my wife back. The guy my wife talked to told her 480 for install plus 85 for realignment. The guy I talked to said 930, 127 of which was alignment.
#68
#69
I'm guessing you want to get it installed so it's all ready when your back? But really, 2 days yourself and you'd have it done and just need an alignment. It is VERY simple straightforward install, no special tools needed. I did my last one with 100% hand tools, nothing fancy at all.
#70
When you got your kit, did the instructions have a list of everythign thats needed in it? I have seen a few people say that got stopped because they needed a spring compressor, and a pitman puller. Can you not use a 2 jaw puller to get the pitman off?
#71
http://www.canadiantire.ca/AST/brows...m%2BPuller.jsp
I believe the instructions said a list of reccommend tools. One thing you will need is some sort of sazall to cut off the control arm bolt, because the exhaust is in the way.
#74
You think a angle grinder with a cutter would do the job? I got one of those sitting around the house.
Also, what do I measure to ensure that the axle is centered properly once I install the new adjustable trac bar?
Edit: I found the instructions online that say what to cut:
Due to clearance issues with the stock exhaust, the passenger side upper
control arm frame mounting hardware will need to be
cut off.
cut off.
#75
http://thurenfabrication.com/align.html
